Spec me a mountain bike £500
18 Oct 2002
England
Saracen Mantra Pro, most local dealers will discount them a little if you ask nicely.
Tbh though bikes at this price point are much of a muchness.
18 Oct 2002
England
Looks pretty decent just concerned about having just 20 gears.
Don't fall for the more gears is best gears thing - in fact 99% of the time you'd want to be going for 10 or 11 over 20 or 30!
First few bikes I got had 30 gears, I'm now down to 20 gears and it's miles better - less weight, less frequent gear changing, less cog swapping also means less chance of a derail, more reliable.
Look at the high end modern bikes on the internet - the very best have "only" got 10 or 11 gears! Unless you've got lady legs you're really honestly not going to struggle with "only" 20 gears - it'll be fine.
OP
17 Jul 2015
No problem lads just thought the more gears the better range I'd have.
I haven't had a mountain bike for years used mainly ride bmx when I was young.
This is just for fun, road and off road. No competition.
Are air forks better than spring?
9 Nov 2005
Southampton
Raidon forks are as good as you are like to get for ~£500.
Number of gears makes no odds, it's the range and how big the jumps are between them. My Voodoo Wazoo had a "megarange" 8-speed cassette, the easiest two sprockets were 26T and 34T, it made the change to the easiest gear very clunky. Jumps of ~4 and under are far smoother.
For something a bit more out there, http://www.gooutdoors.co.uk/calibre-dune-fat-bike-p347149 is ~£460 after buying through Topcashback.
OP
17 Jul 2015
Yeah I am liking the Halford one thanks :)
Hate this one though!
I must have air front forks and hydraulic brakes.
Do you not like the bike I posted?
12 Apr 2007
The vitus is not bad but suntour xct/xcm/xcr forks are thier budget range, the suntour raidon is a step up.
Forks are expensive to upgrade.
The trek and rhe specialized linked above are also running budget forks.
OP
17 Jul 2015
Thanks buddy, so do you recommend a bike not listed above?
12 Apr 2007
The voodoo bizango from halfords is slightly better than the boardman, but it's listed at £600, but if you can get it discounted/on offer it has bettter kit on it.
Out of the above the boardman is best.
OP
17 Jul 2015
I'll check that out thanks. Might up the budget a bit ;)
