Hey, could my card still be under warranty? It's an MSI bought 2 years ago. Worth calling oc?
IIRC, most of the 750TI's had a 3 year warranty. If it were me, I'd buy a 1070 and RMA the 750TI, then sell whatever they send me back.
They might send you a suitable card replacement anyway since the 780ti was such an expensive card anyway, i would go down that route first before buying anything.
RMA it first if I were you, you might receive an upgraded card anyway that would suit your needs.
Ah, my mistake, I read it as 750TI and not 780TI. Assuming they don't have a replacement 780TI, you'll most likely be offered a 980 or if you're lucky, a 1060. If you really are happy with it's performance, then that's cool. If not, now's a good opportunity to buy a 1070 if you want a decent upgrade.
1060 almost as fast as a 980ti in GOW 4 :D
Hi so my card died tonight after 2 years and 1 month bought from OC.
I don't have time to do proper research so please throw some options at me.
Need to stay with Nvidia as I have a Gsync monitor. I was happy with the performance of my dead card. It just died. Showing wacky artifacts everywhere and now windows wont even show up - seen similar death signs with a few cards over the years.
Thx
RMA that thing and get it done, may be a free upgrade.
