Yeah I think if you placed an i5 or i7 at stock clock that most people would be running with a 1070/1080 then you won't see this anyways and Nvidia will still be all good.
What it does show is that really the AMD CPU isn't good enough because you are still losing a number of FPS due to the CPU no matter how you cut it. Yeah performance is better but I am not sure anyone will see that in real world scenarios unless we are suggesting people start buying i3 processors with the latest AMD cards?
Edit: Try checking the tables for 1440p direct next time as well rather than 1080p as as soon as you do that Nvidia with the FX is ahead again. Rather silly to compare to different resolutions to claim its the CPU. All that says is it's clear that Nvidia haven't optimised the drive for the 1080 to run at 1080p as they believe people will use it at 1440p and 4k accoridngly. Tie that in because the fact that it gains nothing over the 980Ti at only 1080p res but has significant increase in performance at the other resolution would bolster that argument/train of thought.
