Learning DIY car maintenance
I think it helps having a second car available whilst you're working on the other.
The last thing you need in the beginnings of learnings is to have to put an unfinished car back together to go to work on Monday.
Good tools and the right tools are essential. E.g don't round off a hex nut trying to use a 12 point socket one.
Other than that, good weather if you don't have a garage.
Before you do anything, read up on how to safely jack a car up. You can do some serious damage to the car or yourself if not do one right. Once you know the basic principles you will get more confident and you will be able to jack up most cars safely. Get yourself a nice Halfords pro tool kit. Wil be a good start.
From my 17 to 25 years old days of owning loads of crap cars that broke down every week or more...
Same way I learnt. Youtube (or the internet) didnt exist when I started tinkering, off down halfords and grabbed a haynes, set of spanners and a big hammer :D
Gloves gloves gloves
Either latex for brakes and oils or mechanics gloves to save your knuckles or both.
Bitch Mitts! I just cant wear gloves and work, wish I could as it would be way cleaner and safer :) Only exception I make is welding, sunburn is nasty from it :D
Christ, if I'd only had YouTube over my formative years with spanners! I'd have saved days..... :o :D
Self taught (mostly wrongly when I've ignored the Haynes manual :o) I'm now not competent enough to guarantee getting every fault fixed,but I did cure a trailer air leak and reattached a truck turbo hose, none of which I'd have had the first idea about without my amateur spannering on my cars.
Go for it!
The biggest pain in the arse if you don't have anyone to show you is when things go wrong and you encounter snapped bolts/ screw rounds off, it seems like you just can't access an area or you really don't think x compinent should be taking that much abuse (worse when it really, really shouldn't be!).
But, sometimes the best way to figure it out is just to experience it.... unfortunately just not the quickest.
(Non French/Italian)Cars are put together pretty logically for the most part which makes learning quite easy
I HATE Scotty Kilmer with a passion. The guy thinks he knows it all when quite often he talks out of his backside.
I pretty much obtain the following and aggregate them for my approach:
  • Workshop manual (usually from owners club)
  • Guide posted by someone from owners club
  • Haynes Manual
The workshop manual is usually a pretty rigid example of how to do the job, doesn't offer much explanation of why you should do things a particular way and often assumes you have all the proprietary tools for the job.
Owners club guides usually offers a more practical insight as to why you need to do certain things and it's usually written in a more comprehendable "bedroom mechanic english". They also typically (and rightly or wrongly) advise how you can avoid using proprietary tools, and other shortcuts/insights. However, a lot of the time they miss out things, and are subject to any mistakes or assumptions the writer has made.
The Haynes manual is sort of a combination of the two, but can be vague in places.
An example of the above is the timing belt I recently did on the Evo, the workshop manual assumes you have all the tools, doesn't really detail the stripping down you need to do to get to the timing assembly, assumes you have all the necessary tools and a beam-type torque wrench (which seem to be like hens teeth in this country). It doesn't really explain things like why it suggests you should set the timing assembly to 1 tooth BTDC in places, and the actual reasons why you are doing specific things in the process.
The "go-to" owners club guide explains things more practically but negates to mention certain things like the fact you need to remove the power steering pump to replace an idler pulley, and i'm reasonably certain that the whole process of tensioning the belt is flawed.
In this case, as there is no Haynes for the Evo - essentially I had to research the whole thing and generate an aggregate approach that i'm happy with.
The above example is an extreme, particularly as the timing process on the 4G63T is a bit of a pig anyway, but it gives an insight into how I approach such a job.
Another recommendation is that you find another pal who is also interested or does his own mechanical work and learn from him/each other. Sanity checking and a second opinion is invaluable when doing these sorts of things.
He is a rather Marmite character. His earlier videos are better I think, his more recent stuff I just don't think they're as good.
Oils easy.
Undo and drain. Refit bung.
Refill.
I gave up trying to undo my sump plug earlier and asked my Dad to do it. After taking the pee out of me for a couple of minutes, he went outside to help
Props to him, he did get it undone. But now has a bag of frozen peas on his sprained wrist. :p
