Interesting article. https://www.theguardian.com/money/2...ase-in-number-of-graduates-bad-for-uk-economy
I of course understand the value of a good degree in a subject that nets you a job in the field that you have your heart set on working in.
However, I have watched people for years in the UK going to university, doing some mickey-mouse degree they weren't really interested in, ending up with tens of thousands of debt, all to simply say they have a degree because that is the "minimum level" that many employers consider, even in jobs where nowhere near degree-level knowledge is required.
What real value does that token degree add in the current market, when fresh graduates are then also often commonly and bizarrely refused a job for 'not having any experience'? Catch 22, it seems.
What I think it is doing is pushing a backwards mentality where if for whatever reason you don't have a Bachelors degree then you have less value to the job market, and in the end all it will do is create such a sea of generic mediocrity that only the best degrees from the best universities get recognition. That simply isn't true or fair, and I think it has degraded and distorted the value of degrees themselves.
