Evening, I am after some advice.. On 2nd October my partner bought a car at a garage in Bradford, we are located in Newcastle. We drove the 80 mile trip and looked at the car and decided to take it and finished the sale at just before 4pm on a Sunday when they close.
Driving home my partner found that the steering wheel controls for the volume were not working correctly, they don't put the volume up and down, it only mutes it (even the + button mutes it). A day or so later she told me she thinks it is misfiring but took me out to show me and it didn't do it. Then she said she thought it happened again, so I took it out and it wasn't doing it. It's got a little more often now so rather than intermittent it seems more permanent (on acceleration only). They gave a warranty with the car through warrantywise, but it is bronze so offers next to no cover (This covers engine moving parts, gearbox, drivetrain and clutch) neither of which can be associated with a misfire so I am confident that warranty will not cover the resolution of this issue.
As per the instructions though I called the warranty company and asked what to do, they said take it to a VAT registered garage and get it diagnosed then have the garage call them. If they cover it, they pay for fix and diagnostics, if they don't then I pay the diagnostics and have to fix it. I don't believe I should be in this position due to the consumer rights so called the garage and asked politely what his thoughts are (never mentioned rights etc) and he just kept saying 'if the warranty don't fix it then it's not warranted'. So I have wrote the below, is this suitable to send? I've took out the garage name, car reg etc.
Hello,
I purchased a car from <Garage Name> on 02/10/2016, Car Registration <123456> for £0000. We test drove the car and it appeared to drive with no issues so a sale was agreed. On the journey home, while trying to adjust the volume of the radio using the steering wheel we found that the buttons to control this were not working correctly. As the garage is 80 miles away from us and the sale was completed at 4pm when you were closing we were unable to return to the garage for assistance. Although we test drove the car, it is not reasonable to expect us to set up and test every single feature prior to sale.
A further issue developed which was an intermittent misfire on acceleration which was not apparent on the test drive due to being intermittent, alongside this the car from cold sometimes struggles to start. We did see this lazy start at the garage, but the salesman advised the car might struggle to start as it has been sitting there a couple of weeks. The car was purchased with 93071 miles and has now got 93430 miles at the time if writing this email (11/10/16). As the problem was intermittent we were unable to correctly understand what was happening to take it to a garage and there were no lights on the dash board which would have suggested a fault. However the problem has now became more apparent and although still not showing an engine management light it is now clear that it is a misfire and a cold start issue as it is fine when warm. We have contacted the warranty company as per instructions, who advise the process is to take the car to a garage and have it diagnosed. If the issue is covered under warranty then they will cover the repair cost and diagnosis cost however the warranty cover we have been given is bronze. This covers engine moving parts, gearbox, drivetrain and clutch, neither of which can be associated with a misfire so I am confident that warranty will not cover the resolution of this issue.
I called to ask for some advice on how to proceed, after explaining the above to you and was given the response of ‘if they don’t fix it then it’s not warranted’. I mentioned that because I don’t believe it is going to be covered under the very basic warranty offered, what would you advise to do as you would need to make an attempt to repair the car. This is a little more difficult as we are not local, if we were local I would expect for you to book us into your mechanic to investigate but as we are a long distance I was unsure if you would prefer to cover the costs locally, or recover the car and use your own mechanic. Again I was just told if the warranty don’t cover it we don’t care and it is my problem. I tried to explain that under the consumer rights act documented here: http://www.autotrader.co.uk/content...ing-car-buyers-come-into-force-on-october-1st on the website where the car was advertised and here http://www.legislation.gov.uk/ukpga/2015/15/contents/enacted on the government site that this gives us an entitlement to a repair, replacement or reject the car. But again was told ‘you must follow the warranty instructions’ which I am absolutely happy to do, however if it is not covered under warranty then I will be out of pocket with a diagnostics fee. The other issue is with the steering wheel controls. Please can you advise on how you wish to proceed, either cover the cost for me to have the issues resolved locally or arrange collection of the car, with a curtsey car to allow us to drive while the car is away as it will be an extended duration since your mechanic is located 80 miles from us. At this moment, we are only looking to have the car repaired and not currently rejecting the contract as per our rights in section 19, part 3 on the legislation.gov.uk link above.
I look forward to hearing from you,
Kind Regards
Craig
Hello,
Kind Regards
Craig
