For those who have not yet, and use headphones often on the S7, be sure to enable Adapt Sound and run through the setup to tailor the DAC to your ears and earphones. It really makes a sizeable difference, even though the DAC is good by default anyway.
This applies to both Bluetooth and wired earphones.
Maybe a rogue app? Usually is the case.
I'm getting 7+hrs SoT comfortably again after a few weeks of not using Chrome anymore.
have there been any problems with the S7/Edge?
Just to confirm....S7 battery is some what decent and on par with other phones right?
As this is what I regularly see:
I have been considering getting one of these phones as an upgrade from my old Nexus 5 but was curious about a couple of things
Thanks for any answers in advance
- The S7 & the Edge both seem to have similar specs apart from the screen size/design. Other than the size of the screen is there any advantage to go with the edge over the normal S7 considering its normally more expensive? (ie are the curved edge features actually useful or gimicky)
- The note 7 obviously has had one or two battery issues
- Is the Samsung VR actually any good as a VR headset? (not expecting to be running around in Skyrim or anything but would like some enjoyable VR experiences without the screen door effect the older occulus rift had)
Click on the graph and post a screen shot. It looks like you have a rogue app keeping the phone awake.
Nope, if I do I turn it off once finished.You have Bluetooth on?
Something is stopping it from going to sleep.
Been using a Note 7 rom on my S7 Edge for a while now
