How to stop Win 10 replacing drivers?
9 Jul 2003
Hi
Having an issue with my laptop since the anniversary update where Windows keeps overwriting the intel chipset driver causing the CPU to throttle right back instead of responding to system demands as usual.
I can fix it by using the driver found by the HP support assistant but after a few days Windows 10 replaces it with the dodgy driver.
Is there way to force a driver to stick?
And any way to make drivers an optional / opt in update rather than just letting Windows mess things up?
Thanks
Im having the same sort of issue with my Wifi drivers, Windows 10 Aniversary update has basically rendered my PC useless (cant get on the net)... So id like to know how to stop auto updates too.
There is an option in advanced system properties but doesn't seem to work reliably and mostly just seems to control extra fluff like icons and support programs rather than the core driver.
I'm not sure this works but this is the only settings you can change:
Control Panel\System and Security\System
Advanced System Settings
Hardware Tab
Device Installation Settings
Choose the 'No' option.
As far as I know you can't reliably stop Windows 10 messing around with drivers.
I've never had any issues with windows 10 messing around with drivers since it doesn't, but that might be because it's abiding by my old windows 8.1 windows update settings of only downloading updates for OS components only (I had to force it to download graphics drivers since it wiped the 8.1 drivers out and defaulted to the generic windows display adapter driver after I upgraded).
Since the change to it the setting in advanced system properties seems to be very hit and miss in its behaviour - some people who've upgraded from older OSes or older builds of 10 seem to have the old behaviour if its set to disable auto updating of drivers, for others it does nothing at all and for others it just controls icons and additional fluff - for me it works unreliably for a short while it stops drivers from auto updating but at some random interval they will.
Its long past time MS put proper manual control over drivers and updates back in the OS.
