email template - best way to send a complicated html/php load of text
12 Feb 2006
Surrey
so i've decvided to make the quotes customers get from our website nicer. they currenlty get a basic plain text email come through listing rooms, price etc. it's fine but ugly
i've made a nice simple html template that i now want to use.
this is how i've done it before
Code:
if ($typediscount==1) {
$body_priceBreakdown .= "Last Minute Discount: <b>-&pound;$discount_date</b><br />";
if ($typediscount==2) {
$body_priceBreakdown .= "Advanced Booking Discount: <b>-&pound;$discount_date</b><br />";
and then after the whole quote is made i put $body_priceBreakdown and $body_property etc into one variable called $body_full and do the following line
Code:
mail($your_email, "Online Quote", $body_full, "From: $your_email\r\nReply-To: $email\r\nContent-Type: text/html; charset=ISO-8859-1\r\nMIME-Version: 1.0");
this works fine before when it was just plain text, but now the email template is over 1000 lines long, with php within it. how would be the best way to store the whole template as one variable to save it as $body_full, or perhaps is there another better way i'm not thinking of?
i've had a look and not entirely sure it'll work how i want.
is there not a way to say everything say between line 1 to 1000, include that as the body of the email, but work out what the php variable is so it doesn't show <?php echo $variable; ?> but instead the value of the variables?
The examples I linked to use a class to create an email, which is far more flexible than your current solution. Any php will be processed upon execution so if you had something like
Code:
Dear <?php echo $Firstname ?>
The end result would contain the value of the variable $Firstname. Let's pretend that's set to "Dave":
Code:
Dear Dave
If you post the full code, it might be easier to suggest something for you. Obviously remove anything sensitive like passwords.
below is the full template. the php isn't in this as i didn't see the point of adding it all in without knowing how i'll get this template to be sent in an email, but any of the words that would be displayed will be a php variable, as this template will be used for more then just standard cleaning
PHP:
** Quick modification **
We are using width of 600 for the whole content,
you can change it any size you want (e.g. 600).
The fastest and safest way is to use find & replace
Sizes: [
		wrapper   : '600',
		columns   : '210',
		x-columns : [
						left : '90',
						right: '350'
	<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
	<html xmlns="http://www.w3.org/1999/xhtml">
	<head>
		<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
		<meta name="viewport" content="width=device-width, initial-scale=1.0">
		<meta http-equiv="X-UA-Compatible" content="IE=edge,chrome=1">
		<meta name="format-detection" content="telephone=no" /> <!-- disable auto telephone linking in iOS -->
		<title>Mayer Cleaning Quotation</title>
		<style type="text/css">
			/* RESET STYLES */
			html { background-color:#E1E1E1; margin:0; padding:0; }
			body, #bodyTable, #bodyCell, #bodyCell{height:100% !important; margin:0; padding:0; width:100% !important;font-family:Helvetica, Arial, "Lucida Grande", sans-serif;}
			table{border-collapse:collapse;}
			table[id=bodyTable] {width:100%!important;margin:auto;max-width:600px!important;color:#7A7A7A;font-weight:normal;}
			img, a img{border:0; outline:none; text-decoration:none;height:auto; line-height:100%;}
			a {text-decoration:none !important;border-bottom: 1px solid;}
			h1, h2, h3, h4, h5, h6{color:#5F5F5F; font-weight:normal; font-family:Helvetica; font-size:20px; line-height:125%; text-align:Left; letter-spacing:normal;margin-top:0;margin-right:0;margin-bottom:10px;margin-left:0;padding-top:0;padding-bottom:0;padding-left:0;padding-right:0;}
			/* CLIENT-SPECIFIC STYLES */
			.ReadMsgBody{width:100%;} .ExternalClass{width:100%;} /* Force Hotmail/Outlook.com to display emails at full width. */
			.ExternalClass, .ExternalClass p, .ExternalClass span, .ExternalClass font, .ExternalClass td, .ExternalClass div{line-height:100%;} /* Force Hotmail/Outlook.com to display line heights normally. */
			table, td{mso-table-lspace:0pt; mso-table-rspace:0pt;} /* Remove spacing between tables in Outlook 2007 and up. */
			#outlook a{padding:0;} /* Force Outlook 2007 and up to provide a "view in browser" message. */
			img{-ms-interpolation-mode: bicubic;display:block;outline:none; text-decoration:none;} /* Force IE to smoothly render resized images. */
			body, table, td, p, a, li, blockquote{-ms-text-size-adjust:100%; -webkit-text-size-adjust:100%; font-weight:normal!important;} /* Prevent Windows- and Webkit-based mobile platforms from changing declared text sizes. */
			.ExternalClass td[class="ecxflexibleContainerBox"] h3 {padding-top: 10px !important;} /* Force hotmail to push 2-grid sub headers down */
			/* /\/\/\/\/\/\/\/\/ TEMPLATE STYLES /\/\/\/\/\/\/\/\/ */
			/* ========== Page Styles ========== */
			h1{display:block;font-size:26px;font-style:normal;font-weight:normal;line-height:100%;}
			h2{display:block;font-size:20px;font-style:normal;font-weight:normal;line-height:120%;}
			h3{display:block;font-size:17px;font-style:normal;font-weight:normal;line-height:110%;}
			h4{display:block;font-size:18px;font-style:italic;font-weight:normal;line-height:100%;}
			.flexibleImage{height:auto;}
			.linkRemoveBorder{border-bottom:0 !important;}
			table[class=flexibleContainerCellDivider] {padding-bottom:0 !important;padding-top:0 !important;}
			body, #bodyTable{background-color:#E1E1E1;}
			#emailHeader{background-color:#E1E1E1;}
			#emailBody{background-color:#FFFFFF;}
			#emailFooter{background-color:#E1E1E1;}
			.nestedContainer{background-color:#F8F8F8; border:1px solid #CCCCCC;}
			.emailButton{background-color:#205478; border-collapse:separate;}
			.buttonContent{color:#FFFFFF; font-family:Helvetica; font-size:18px; font-weight:bold; line-height:100%; padding:15px; text-align:center; background: #119555;}
			.buttonContent a{color:#FFFFFF; display:block; text-decoration:none!important; border:0!important;}
			.emailCalendar{background-color:#FFFFFF; border:1px solid #CCCCCC;}
			.emailCalendarMonth{background-color:#205478; color:#FFFFFF; font-family:Helvetica, Arial, sans-serif; font-size:16px; font-weight:bold; padding-top:10px; padding-bottom:10px; text-align:center;}
			.emailCalendarDay{color:#205478; font-family:Helvetica, Arial, sans-serif; font-size:60px; font-weight:bold; line-height:100%; padding-top:20px; padding-bottom:20px; text-align:center;}
			.imageContentText {margin-top: 10px;line-height:0;}
			.imageContentText a {line-height:0;}
			#invisibleIntroduction {display:none !important;} /* Removing the introduction text from the view */
			/*FRAMEWORK HACKS & OVERRIDES */
			span[class=ios-color-hack] a {color:#275100!important;text-decoration:none!important;} /* Remove all link colors in IOS (below are duplicates based on the color preference) */
			span[class=ios-color-hack2] a {color:#205478!important;text-decoration:none!important;}
			span[class=ios-color-hack3] a {color:#8B8B8B!important;text-decoration:none!important;}
			/* A nice and clean way to target phone numbers you want clickable and avoid a mobile phone from linking other numbers that look like, but are not phone numbers.  Use these two blocks of code to "unstyle" any numbers that may be linked.  The second block gives you a class to apply with a span tag to the numbers you would like linked and styled.
			Inspired by Campaign Monitor's article on using phone numbers in email: http://www.campaignmonitor.com/blog/post/3571/using-phone-numbers-in-html-email/.
			.a[href^="tel"], a[href^="sms"] {text-decoration:none!important;color:#606060!important;pointer-events:none!important;cursor:default!important;}
			.mobile_link a[href^="tel"], .mobile_link a[href^="sms"] {text-decoration:none!important;color:#606060!important;pointer-events:auto!important;cursor:default!important;}
			/* MOBILE STYLES */
			@media only screen and (max-width: 480px){
				/*////// CLIENT-SPECIFIC STYLES //////*/
				body{width:100% !important; min-width:100% !important;} /* Force iOS Mail to render the email at full width. */
				/* FRAMEWORK STYLES */
				CSS selectors are written in attribute
				selector format to prevent Yahoo Mail
				from rendering media query styles on
				desktop.
				/*td[class="textContent"], td[class="flexibleContainerCell"] { width: 100%; padding-left: 10px !important; padding-right: 10px !important; }*/
				table[id="emailHeader"],
				table[id="emailBody"],
				table[id="emailFooter"],
				table[class="flexibleContainer"],
				td[class="flexibleContainerCell"] {width:100% !important;}
				td[class="flexibleContainerBox"], td[class="flexibleContainerBox"] table {display: block;width: 100%;text-align: left; }
				The following style rule makes any
				image classed with 'flexibleImage'
				fluid when the query activates.
				Make sure you add an inline max-width
				to those images to prevent them
				from blowing out.
				td[class="imageContent"] img {height:auto !important; width:100% !important; max-width:100% !important; }
				img[class="flexibleImage"]{height:auto !important; width:100% !important;max-width:100% !important;}
				img[class="flexibleImageSmall"]{height:auto !important; width:auto !important;}
				Create top space for every second element in a block
				table[class="flexibleContainerBoxNext"]{padding-top: 10px !important; }
				Make buttons in the email span the
				full width of their container, allowing
				for left- or right-handed ease of use.
				table[class="emailButton"]{width:100% !important;}
				td[class="buttonContent"]{padding:0 !important;}
				td[class="buttonContent"] a{padding:15px !important;}
			/*  CONDITIONS FOR ANDROID DEVICES ONLY
			*   http://developer.android.com/guide/webapps/targeting.html
			*   http://pugetworks.com/2011/04/css-media-queries-for-targeting-different-mobile-devices/ ;
			@media only screen and (-webkit-device-pixel-ratio:.75){
				/* Put CSS for low density (ldpi) Android layouts in here */
			@media only screen and (-webkit-device-pixel-ratio:1){
				/* Put CSS for medium density (mdpi) Android layouts in here */
			@media only screen and (-webkit-device-pixel-ratio:1.5){
				/* Put CSS for high density (hdpi) Android layouts in here */
			/* end Android targeting */
			/* CONDITIONS FOR IOS DEVICES ONLY
			@media only screen and (min-device-width : 320px) and (max-device-width:568px) {
			/* end IOS targeting */
		</style>
			Outlook Conditional CSS
			These two style blocks target Outlook 2007 & 2010 specifically, forcing
			columns into a single vertical stack as on mobile clients. This is
			primarily done to avoid the 'page break bug' and is optional.
			More information here:
			http://templates.mailchimp.com/development/css/outlook-conditional-css
		<!--[if mso 12]>
				.flexibleContainer{display:block !important; width:100% !important;}
			</style>
		<![endif]-->
		<!--[if mso 14]>
			</style>
		<![endif]-->
	</head>
	<body bgcolor="#E1E1E1" leftmargin="0" marginwidth="0" topmargin="0" marginheight="0" offset="0">
		<!-- CENTER THE EMAIL // -->
		1.  The center tag should normally put all the
			content in the middle of the email page.
			I added "table-layout: fixed;" style to force
			yahoomail which by default put the content left.
		2.  For hotmail and yahoomail, the contents of
			the email starts from this center, so we try to
			apply necessary styling e.g. background-color.
		<center style="background-color:#E1E1E1;">
			<table border="0" cellpadding="0" cellspacing="0" height="100%" width="100%" id="bodyTable" style="table-layout: fixed;max-width:100% !important;width: 100% !important;min-width: 100% !important;">
				<tr>
					<td align="center" valign="top" id="bodyCell">
						<!-- EMAIL HEADER // -->
							The table "emailBody" is the email's container.
							Its width can be set to 100% for a color band
							that spans the width of the page.
						<table bgcolor="#E1E1E1" border="0" cellpadding="0" cellspacing="0" width="600" id="emailHeader">
							<!-- HEADER ROW // -->
							<tr>
								<td align="center" valign="top">
									<!-- CENTERING TABLE // -->
									<table border="0" cellpadding="0" cellspacing="0" width="100%">
										<tr>
												<!-- FLEXIBLE CONTAINER // -->
												<table border="0" cellpadding="10" cellspacing="0" width="600" class="flexibleContainer">
													<tr>
														<td valign="top" width="600" class="flexibleContainerCell">
															<!-- CONTENT TABLE // -->
															<table align="left" border="0" cellpadding="0" cellspacing="0" width="100%">
																<tr>
																		The "invisibleIntroduction" is the text used for short preview
																		of the email before the user opens it (50 characters max). Sometimes,
																		you do not want to show this message depending on your design but this
																		text is highly recommended.
																		You do not have to worry if it is hidden, the next <td> will automatically
																		center and apply to the width 100% and also shrink to 50% if the first <td>
																		is visible.
																	<td align="left" valign="middle" id="invisibleIntroduction" class="flexibleContainerBox" style="display:none !important; mso-hide:all;">
																		<table border="0" cellpadding="0" cellspacing="0" width="100%" style="max-width:100%;">
																			<tr>
																				<td align="left" class="textContent">
																					<div style="font-family:Helvetica,Arial,sans-serif;font-size:13px;color:#828282;text-align:center;line-height:120%;">
																						Copy of your Mayer Cleaning Quotation.
																					</div>
																				</td>
																			</tr>
																		</table>
																	</td>
																	<td align="right" valign="middle" class="flexibleContainerBox">
																			<tr>
																					<!-- CONTENT // -->
																				</td>
																			</tr>
																		</table>
																	</td>
																</tr>
															</table>
														</td>
													</tr>
												</table>
												<!-- // FLEXIBLE CONTAINER -->
											</td>
										</tr>
									</table>
									<!-- // CENTERING TABLE -->
								</td>
							</tr>
							<!-- // END -->
						</table>
						<!-- // END -->
						<!-- EMAIL BODY // -->
						<table bgcolor="#FFFFFF"  border="0" cellpadding="0" cellspacing="0" width="600" id="emailBody">
							<!-- MODULE ROW // -->
								To move or duplicate any of the design patterns
								in this email, simply move or copy the entire
								MODULE ROW section for each content block.
							<tr>
										The centering table keeps the content
										tables centered in the emailBody table,
										in case its width is set to 100%.
									<table border="0" cellpadding="0" cellspacing="0" width="100%" style="color:#FFFFFF;" bgcolor="#3498db">
										<tr>
													The flexible container has a set width
													that gets overridden by the media query.
													Most content tables within can then be
													given 100% widths.
												<table border="0" cellpadding="0" cellspacing="0" width="600" class="flexibleContainer">
													<tr>
														<td align="center" valign="top" width="600" class="flexibleContainerCell">
															The content table is the first element
																that's entirely separate from the structural
																framework of the email.
															<table border="0" cellpadding="30" cellspacing="0" width="100%">
																<tr>
																	<td align="center" valign="top" class="textContent">
																		<h1 style="color:#FFFFFF;line-height:100%;font-family:Helvetica,Arial,sans-serif;font-size:35px;font-weight:normal;margin-bottom:10px;text-align:center;">Mayer Cleaning Quotation</h1>
																		<h2 style="text-align:center;font-weight:normal;font-family:Helvetica,Arial,sans-serif;font-size:17px;margin-bottom:10px;color:#205478;line-height:135%;">Quote Reference Number: <a href='#' title='View Online'><b>101022_6030</b></a></h2>
																		<div style="text-align:center;font-family:Helvetica,Arial,sans-serif;font-size:15px;margin-bottom:0;color:#FFFFFF;line-height:165%;">If you have any questions, perhaps about the price, availability, or maybe even why we're the number one choice in the area for this service, please do not hesitate to get in touch. Either reply directly to this email or get in touch on 01483 905007.</div>
																	</td>
																</tr>
															</table>
															<!-- // CONTENT TABLE -->
														</td>
													</tr>
												</table>
											</td>
										</tr>
									</table>
								</td>
							</tr>
							<!-- // MODULE ROW -->
							<!--  The "mc:hideable" is a feature for MailChimp which allows
								you to disable certain row. It works perfectly for our row structure.
								http://kb.mailchimp.com/article/template-language-creating-editable-content-areas/
							<tr mc:hideable>
										<tr>
												<table border="0" cellpadding="30" cellspacing="0" width="600" class="flexibleContainer">
													<tr>
																<tr>
																	<td align="left" valign="top" class="flexibleContainerBox">
																		<table border="0" cellpadding="0" cellspacing="0" width="350" style="max-width: 100%;">
																			<tr>
																					<h3 style="color:#5F5F5F;line-height:125%;font-family:Helvetica,Arial,sans-serif;font-size:19px;font-weight:normal;margin-top:0;margin-bottom:3px;text-align:left;">Service</h3>
																					<div style="text-align:left;font-family:Helvetica,Arial,sans-serif;font-size:15px;margin-bottom:0;color:#5F5F5F;line-height:200%;">Moving House Cleaning Service</div>
																					<div style="text-align:left;font-family:Helvetica,Arial,sans-serif;font-size:15px;margin-bottom:0;color:#5F5F5F;line-height:200%;">Carpet Cleaning Service</div>
																					<div style="text-align:left;font-family:Helvetica,Arial,sans-serif;font-size:15px;margin-bottom:0;color:#5F5F5F;line-height:200%;">Appliances</div>
																					<div style="text-align:left;font-family:Helvetica,Arial,sans-serif;font-size:15px;margin-bottom:0;color:#5F5F5F;line-height:200%;">Mayer Guarantee</div>
																					<div style="text-align:left;font-family:Helvetica,Arial,sans-serif;font-size:15px;margin-bottom:0;color:#5F5F5F;line-height:200%;color: #FFFFFF;">.</div>
																					<div style="text-align:right;font-family:Helvetica,Arial,sans-serif;font-size:15px;margin-bottom:0;color:#5F5F5F;line-height:200%;">Sub Total:</div>
																					<div style="text-align:right;font-family:Helvetica,Arial,sans-serif;font-size:15px;margin-bottom:0;color:#5F5F5F;line-height:200%;">VAT 10% (limited time offer):</div>
																					<div style="text-align:right;font-family:Helvetica,Arial,sans-serif;font-size:15px;margin-bottom:0;color:#5F5F5F;line-height:200%;">Total Online Discount (2%):</div>
																					<div style="text-align:right;font-family:Helvetica,Arial,sans-serif;font-size:16px;margin-bottom:0;color:#5F5F5F;line-height:200%;color: #119555; font-weight:bold;">Total Price:</div>
																				</td>
																			</tr>
																		</table>
																	</td>
																		<table class="flexibleContainerBoxNext" border="0" cellpadding="0" cellspacing="0" width="150" style="max-width: 100%;">
																			<tr>
																					<h3 style="color:#5F5F5F;line-height:125%;font-family:Helvetica,Arial,sans-serif;font-size:20px;font-weight:normal;margin-top:0;margin-bottom:3px;text-align:right;">Sub Total</h3>
																					<div style="text-align:right;font-family:Helvetica,Arial,sans-serif;font-size:15px;margin-bottom:0;color:#5F5F5F;line-height:200%;">£150.00</div>
																					<div style="text-align:right;font-family:Helvetica,Arial,sans-serif;font-size:15px;margin-bottom:0;color:#5F5F5F;line-height:200%;">£60.00</div>
																					<div style="text-align:right;font-family:Helvetica,Arial,sans-serif;font-size:15px;margin-bottom:0;color:#5F5F5F;line-height:200%;">£74.00</div>
																					<div style="text-align:right;font-family:Helvetica,Arial,sans-serif;font-size:15px;margin-bottom:0;color:#5F5F5F;line-height:200%; font-style: italic;">Free</div>
																					<div style="text-align:right;font-family:Helvetica,Arial,sans-serif;font-size:15px;margin-bottom:0;color:#5F5F5F;line-height:200%; font-style: italic; color:#FFFFFF;">.</div>
																					<div style="text-align:right;font-family:Helvetica,Arial,sans-serif;font-size:15px;margin-bottom:0;color:#5F5F5F;line-height:200%;">£267.00</div>
																					<div style="text-align:right;font-family:Helvetica,Arial,sans-serif;font-size:15px;margin-bottom:0;color:#5F5F5F;line-height:200%;">£26.20</div>
																					<div style="text-align:right;font-family:Helvetica,Arial,sans-serif;font-size:15px;margin-bottom:0;color:#5F5F5F;line-height:200%;color: #178ad0;">-£5.00</div>
																					<div style="text-align:right;font-family:Helvetica,Arial,sans-serif;font-size:16px;margin-bottom:0;color:#5F5F5F;line-height:200%;color: #119555; font-weight:bold;">£288.20</div>
																				</td>
																			</tr>
																		</table>
																	</td>
																</tr>
															</table>
														</td>
													</tr>
												</table>
											</td>
										</tr>
									</table>
								</td>
							</tr>
							<tr>
										<tr style="padding-top:0;">
													<tr>
														<td style="padding-top:0;" align="center" valign="top" width="600" class="flexibleContainerCell">
															<table border="0" cellpadding="0" cellspacing="0" width="50%" class="emailButton" style="background-color: #3498DB;">
																<tr>
																	<td align="center" valign="middle" class="buttonContent" style="padding-top:15px;padding-bottom:15px;padding-right:15px;padding-left:15px;">
																		<a style="color:#FFFFFF;text-decoration:none;font-family:Helvetica,Arial,sans-serif;font-size:20px;line-height:135%;" href="#" target="_blank">Book with Mayer</a>
																	</td>
																</tr>
															</table>
																			<tr>
																				<td valign="top" class="textContent">
																						The "mc:edit" is a feature for MailChimp which allows
																						you to edit certain row. It makes it easy for you to quickly edit row sections.
																						http://kb.mailchimp.com/templates/code/create-editable-content-areas-with-mailchimps-template-language
																					<div mc:edit="body" style="text-align:center;font-family:Helvetica,Arial,sans-serif;font-size:12px;margin-bottom:0;margin-top:20px;color:#5F5F5F;line-height:135%;"><a href="#">View full breakdown of this quote online here</a></div>
																				</td>
																			</tr>
																		</table>
														</td>
													</tr>
												</table>
											</td>
										</tr>
									</table>
								</td>
							</tr>
							<!-- MODULE DIVIDER // -->
							<tr>
										<tr>
													<tr>
															<table class="flexibleContainerCellDivider" border="0" cellpadding="30" cellspacing="0" width="100%">
																<tr>
																	<td align="center" valign="top" style="padding-top:0px;padding-bottom:0px;">
																			<tr>
																				<td align="center" valign="top" style="border-top:1px solid #C8C8C8;"></td>
																			</tr>
																		</table>
																	</td>
																</tr>
															</table>
														</td>
													</tr>
												</table>
											</td>
										</tr>
									</table>
								</td>
							</tr>
							<!-- // END -->
							<tr>
									<table border="0" cellpadding="0" cellspacing="0" width="100%" bgcolor="#F8F8F8">
										<tr>
													<tr>
																<tr>
																			<tr>
																					<h3 mc:edit="header" style="color:#5F5F5F;line-height:125%;font-family:Helvetica,Arial,sans-serif;font-size:20px;font-weight:normal;margin-top:0;margin-bottom:3px;text-align:left;">Get More with Mayer</h3>
																					<div mc:edit="body" style="text-align:left;font-family:Helvetica,Arial,sans-serif;font-size:15px;margin-bottom:0;color:#5F5F5F;line-height:135%;">At Mayer we believe in giving you more. Below are just some of the benefits you'll enjoy when you select Mayer Cleaning as your cleaning professionals.</div>
																				</td>
																			</tr>
																		</table>
																	</td>
																</tr>
															</table>
														</td>
													</tr>
												</table>
											</td>
										</tr>
									</table>
								</td>
							</tr>
							<tr>
										<tr>
													<tr>
														<td valign="top" width="600" class="flexibleContainerCell" style="background:#3598dc;">
																<tr>
																		<table border="0" cellpadding="0" cellspacing="0" width="210" style="max-width: 100%;">
																			<tr>
																					<h3 style="color:#FFFFFF;line-height:125%;font-family:Helvetica,Arial,sans-serif;font-size:20px;font-weight:normal;margin-top:0;margin-bottom:3px;text-align:left;">Approved by Agencies</h3>
																					<div style="text-align:left;font-family:Helvetica,Arial,sans-serif;font-size:15px;margin-bottom:0;color:#FFFFFF;line-height:135%;">Tried and tested method approved by agencies.</div>
																				</td>
																			</tr>
																		</table>
																	</td>
																		<table class="flexibleContainerBoxNext" border="0" cellpadding="0" cellspacing="0" width="210" style="max-width: 100%;">
																			<tr>
																					<h3 style="color:#FFFFFF;line-height:125%;font-family:Helvetica,Arial,sans-serif;font-size:20px;font-weight:normal;margin-top:0;margin-bottom:3px;text-align:left;">Win Your Security Deposit Back</h3>
																					<div style="text-align:left;font-family:Helvetica,Arial,sans-serif;font-size:15px;margin-bottom:0;color:#FFFFFF;line-height:135%;">Get your full deposit back with our fantastic 72 hr guarantee.</div>
																				</td>
																			</tr>
																		</table>
																	</td>
																</tr>
															</table>
														</td>
													</tr>
												</table>
											</td>
										</tr>
									</table>
								</td>
							</tr>
							<tr>
										<tr>
												<table border="0" cellpadding="30" cellspacing="0" width="600" class="flexibleContainer" style="background:#3598dc;">
													<tr>
																<tr>
																			<tr>
																					<h3 style="color:#FFFFFF;line-height:125%;font-family:Helvetica,Arial,sans-serif;font-size:20px;font-weight:normal;margin-top:0;margin-bottom:3px;text-align:left;">Not Time-Limited</h3>
																					<div style="text-align:left;font-family:Helvetica,Arial,sans-serif;font-size:15px;margin-bottom:0;color:#FFFFFF;line-height:135%;">We work until the job is done, with everything done typically in one day.</div>
																				</td>
																			</tr>
																		</table>
																	</td>
																			<tr>
																					<h3 style="color:#FFFFFF;line-height:125%;font-family:Helvetica,Arial,sans-serif;font-size:20px;font-weight:normal;margin-top:0;margin-bottom:3px;text-align:left;">We Do Everything</h3>
																					<div style="text-align:left;font-family:Helvetica,Arial,sans-serif;font-size:15px;margin-bottom:0;color:#FFFFFF;line-height:135%;">No phoning around 5 different companies, arranging times and dates that each can do. We Do Everything.</div>
																				</td>
																			</tr>
																		</table>
																	</td>
																</tr>
															</table>
														</td>
													</tr>
												</table>
											</td>
										</tr>
									</table>
								</td>
							</tr>
							<tr>
										<tr>
													<tr>
																<tr>
																			<tr>
																					<h3 style="color:#FFFFFF;line-height:125%;font-family:Helvetica,Arial,sans-serif;font-size:20px;font-weight:normal;margin-top:0;margin-bottom:3px;text-align:left;">Full Detailed Invoice</h3>
																					<div style="text-align:left;font-family:Helvetica,Arial,sans-serif;font-size:15px;margin-bottom:0;color:#FFFFFF;line-height:135%;">Full invoice/receipts will be provided, detailing exactly what we have done.</div>
																				</td>
																			</tr>
																		</table>
																	</td>
																			<tr>
																					<h3 style="color:#FFFFFF;line-height:125%;font-family:Helvetica,Arial,sans-serif;font-size:20px;font-weight:normal;margin-top:0;margin-bottom:3px;text-align:left;">Ltd Company</h3>
																					<div style="text-align:left;font-family:Helvetica,Arial,sans-serif;font-size:15px;margin-bottom:0;color:#FFFFFF;line-height:135%;">We are a limited company, showing we are professionals that are here to stay. Agencies love this!</div>
																				</td>
																			</tr>
																		</table>
																	</td>
																</tr>
															</table>
														</td>
													</tr>
												</table>
											</td>
										</tr>
									</table>
								</td>
							</tr>
							<tr>
										<tr>
													<tr>
																<tr>
																			<tr>
																			</tr>
																		</table>
																	</td>
																</tr>
															</table>
														</td>
													</tr>
												</table>
											</td>
										</tr>
									</table>
								</td>
							</tr>
							<!-- // END -->
							<tr>
										<tr>
													<tr>
																<tr>
																			<tr>
																					<h3 style="color:#5F5F5F;line-height:125%;font-family:Helvetica,Arial,sans-serif;font-size:20px;font-weight:normal;margin-top:0;margin-bottom:3px;text-align:left;">Select Mayer Cleaning</h3>
																					<div style="text-align:left;font-family:Helvetica,Arial,sans-serif;font-size:15px;margin-bottom:0;margin-top:3px;color:#5F5F5F;line-height:135%;">Just 2 clicks is all it takes to book this clean in us. Select Mayer Cleaning today and start enjoying your new found free time however you like.</div>
																				</td>
																			</tr>
																		</table>
																	</td>
																</tr>
															</table>
														</td>
													</tr>
												</table>
											</td>
										</tr>
									</table>
								</td>
							</tr>
							<tr>
													<tr>
																<tr>
																	</td>
																</tr>
															</table>
														</td>
													</tr>
												</table>
											</td>
										</tr>
									</table>
								</td>
							</tr>
							<tr>
										<tr>
													<tr>
																<tr>
																			<tr>
																			</tr>
																		</table>
																	</td>
																</tr>
															</table>
														</td>
													</tr>
												</table>
											</td>
										</tr>
									</table>
								</td>
							</tr>
							<!-- // END -->
							<tr>
										<tr>
													<tr>
																<tr>
																		<table border="0" cellpadding="0" cellspacing="0" width="210" style="max-width:100%;">
																			<tr>
																					<img src="http://www.mayercleaning.co.uk/style/images/home_box_247.JPG" width="210" class="flexibleImage" style="max-width:100%;" alt="Text" title="Text" />
																					<h3 style="color:#5F5F5F;line-height:125%;font-family:Helvetica,Arial,sans-serif;font-size:18px;font-weight:normal;margin-top:10px;margin-bottom:3px;text-align:left;">Online Quote & Booking</h3>
																					<div style="text-align:left;font-family:Helvetica,Arial,sans-serif;font-size:13px;margin-bottom:0;color:#5F5F5F;line-height:135%;">Our fully automated system means you can get a quote any time, any day.</div>
																				</td>
																			</tr>
																		</table>
																	</td>
																		<table class="flexibleContainerBoxNext" border="0" cellpadding="0" cellspacing="0" width="210" style="max-width:100%;">
																			<tr>
																					<img src="http://www.mayercleaning.co.uk/style/images/home_box_guarantee.JPG" width="210" class="flexibleImage" style="max-width:100%;" alt="Text" title="Text" />
																					<h3 style="color:#5F5F5F;line-height:125%;font-family:Helvetica,Arial,sans-serif;font-size:18px;font-weight:normal;margin-top:10px;margin-bottom:3px;text-align:left;">Fantastic 72 hr Guarantee</h3>
																					<div style="text-align:left;font-family:Helvetica,Arial,sans-serif;font-size:13px;margin-bottom:0;color:#5F5F5F;line-height:135%;">If you're not fully satisfied, we will gladly return to set anything right (no matter how small) free of charge.</div>
																				</td>
																			</tr>
																		</table>
																	</td>
																</tr>
															</table>
														</td>
													</tr>
												</table>
											</td>
										</tr>
									</table>
								</td>
							</tr>
							<tr>
										<tr>
													<tr>
																<tr>
																			<tr>
																					<img src="http://www.mayercleaning.co.uk/style/images/home_box_insured.JPG" width="210" class="flexibleImage" style="max-width:100%;" alt="Text" title="Text" />
																					<h3 style="color:#5F5F5F;line-height:125%;font-family:Helvetica,Arial,sans-serif;font-size:18px;font-weight:normal;margin-top:10px;margin-bottom:3px;text-align:left;">Fully Insured & Certified
</h3>
																					<div style="text-align:left;font-family:Helvetica,Arial,sans-serif;font-size:13px;margin-bottom:0;color:#5F5F5F;line-height:135%;">We are fully insured & certified many times over for your complete protection and peace of mind.</div>
																				</td>
																			</tr>
																		</table>
																	</td>
																			<tr>
																					<img src="http://www.mayercleaning.co.uk/style/images/home_box_quality.JPG" width="210" class="flexibleImage" style="max-width:100%;" alt="Text" title="Text" />
																					<h3 style="color:#5F5F5F;line-height:125%;font-family:Helvetica,Arial,sans-serif;font-size:18px;font-weight:normal;margin-top:10px;margin-bottom:3px;text-align:left;">Five Star Quality</h3>
																					<div style="text-align:left;font-family:Helvetica,Arial,sans-serif;font-size:13px;margin-bottom:0;color:#5F5F5F;line-height:135%;">The team here at Mayer Cleaning are all trained professionals bringing with them some of the best high-tech cleaning equipment available.</div>
																				</td>
																			</tr>
																		</table>
																	</td>
																</tr>
															</table>
														</td>
													</tr>
												</table>
											</td>
										</tr>
									</table>
								</td>
							</tr>
							<tr>
										<tr>
													<tr>
																<tr>
																			<tr>
																			</tr>
																		</table>
																	</td>
																</tr>
															</table>
														</td>
													</tr>
												</table>
											</td>
										</tr>
									</table>
								</td>
							</tr>
							<!-- // END -->
						</table>
						<!-- // END -->
						<!-- EMAIL FOOTER // -->
						<table bgcolor="#E1E1E1" border="0" cellpadding="0" cellspacing="0" width="600" id="emailFooter">
							<!-- FOOTER ROW // -->
							<tr>
										<tr>
													<tr>
																<tr>
																	<td valign="top" bgcolor="#E1E1E1">
																			<div>Copyright © 2009 - 2016 Mayer. All&nbsp;rights&nbsp;reserved. 01483 905007</div>
																		</div>
																	</td>
																</tr>
															</table>
														</td>
													</tr>
												</table>
											</td>
										</tr>
									</table>
								</td>
							</tr>
						</table>
						<!-- // END -->
					</td>
				</tr>
			</table>
		</center>
	</body>
</html>
Well if you want to put the whole thing into a variable you just do the same thing you were doing and keep adding bits to the variable that contains the email content. At various points you can add specific/dynamic information in using php. Definitely not an efficient way of doing things but it will sort of work but be a nightmare to maintain/change.
You may want to look into some sort of framework to deal with emails for you. Some of them just allow you to paste in a bunch of html and add variables throughout to customise the content, then handle the delivery of the email for you. No point reinventing the wheel. Try this: http://swiftmailer.org/
Also remember to look at security.
My approach to this would be to use the file_get_contents function and use str_replace to replace placeholders with actual data.
For example, have a file named email_template.html and in this file place your email html. Where you need something to be a variable, we'll use a placeholder.
So, first name could be #FirstName#, last name could be #LastName#, quote number could be #QuoteNumber#, etc
You then replace the placeholders using str_replace.
So something like:
PHP:
// Read in the template.
$template = file_get_contents("email_template.html");
// Replace #placeholders#.
$template = str_replace("#FirstName#",    $firstName,   $template);
$template = str_replace("#LastName#",     $lastName,    $template);
$template = str_replace("#QuoteNumber#", $quoteNumber, $template);
// $template can now be used for email body.
