- 1 Dec 2015
OEM is were the money is at I guess . Prob make far more sales then from us lot
I mean, I guess this is theoretically possible since Pascal is even more efficient than that anyway.
This would be more efficient than Pascal. The Rx480 would use under 100w with a 50% reduction in power.
The Rx480 uses around 160w. 50% of 160 = 80. So if it did have a 50% reduction you would be looking at an 80w part. Plenty of headroom to boost clocks well above the gtx1060. It does seem a little far fetched to me but if there is some truth like say 30% your still looking at Pascal efficiency.
The article claims a reduction to 95W from 150W for Polaris 10.
So if you take the difference of 55W and apply it to a real world test, like the 163W average gaming load from Techpowerup, that would make 108W.
The GTX 1080 being 166W.
That would still put it as 20% less efficient than the GTX 1080. The 1080 currently being ~80% more efficient. And that would be essentially on par with the GTX 1060, since the weaker Pascal cards are also less efficient.
It does baffle me how the RX 480 is so much less efficient currently though. As far as I gather Samsung's 14LPP process is supposed to be mildly superior to TSMC's 16FF+.
480 is not particularly efficient for the process - if you take the numbers with a slight pinch of salt and assume a little bit of "marketing/PR" overhead it drops into the realm of possible.
It's not exactly a stretch, According to this video this particular 480 only uses 80-90 watt with stock clocks.
This has a thread on it.
The XFX GTR I got recently uses less power than my 970 does, while performing the same or slightly better in dx11 and way better in dx12. It's rated at 110w, so 95w isn't that far fetched.
I have literally just ordered the 2 MSI 480s in my sig, should I cancel them?
