I ran a stress test with CPU Z and noted what the vCore was at max load, then i noted idle VCore on a 4690K.
Vcore load 1.130v
Vcore Idle 0.708v.
this tells me a increase of 0.42 v is needed for a 3.1Ghz increase from 800mhz idle speed max speed 3.9ghz Turbo , all settings in BIOS on Auto.
Question.
Is it realistic to calculate what Vcore is needed per 1 ghz or even per 200mhz?
because with the above data , i worked it out that a .10v increase in needed per 800mhz increase in clock, all based on how the system automatically regulates Vcore when stressed/idle.
Vcore load 1.130v
Vcore Idle 0.708v.
Question.
