Hi all,
My 3 year old Corsair CX750M shows its age (or low quality?).
It screams when I overclock my i7 6700K to 4.8GHz or higher. And I mean it: screams. Just coil whine is on stock clocks...
5GHz is not possible because of this power supply.
I also get coil whine (coming from the power supply, not the GPU) since I got MSI GTX1070 Gaming 8G. It did also occur when I had GTX980 and GTX980Ti. Whether I use a single modular PCIe cable to connect 1x8 and 1x6 pin, or if 2 separate PCIe cables for 1x8 and 1x6, I get same whine from the PSU.
Running benchmarks that stress GPU to 70%+ and CPU to 60%+ load, PSU sounds like it will explode any second
I am looking for a Gold/Platinum rated power supply. Something sufficient to power:
1x CPU
1x GPU (always 1xGPU, never multi!)
2x HDDs and 4x SSDs (SATA)
1x Fan controller [molex] (6 fans) +3 fans connected to motherboard headers (all use 3pin headers)
1x watercooling pump (fan header)
1x custom LED strip [molex]
If Overclockers would sell nuclear power plant, I'd be buying one straight away
I assume that 600W would be sufficient.
Also I looked at Super Flower, Corsair, Seasonic and Silverstone.
I would like to avoid any other brand.
Budget: about 100-120GBP.
And full modularity is a must.
PS: I do not need a 2kW Super Flower from 8Pack
600-800W will do the job.
What are your suggestions?
1x CPU
