Is this enough paste?
17 Aug 2009
Finchley, London
Hi guys. Just a quick question. I've taken my laptop apart and fixed something. As I'm down at the motherboard, I've taken the opportunity to redo the TIM. I did it a few months ago using the spread method that someone recommended. I spread it very thin but my temps were rubbish. I normally do the centre blob and let the heatsink squish it so I'm doing that again. Here's a pic of my MX-4 on the CPU and GPU. About the right amount?
Also, can someone link me thermal pads to buy for the surrounding vrams? Mine are knackered.
Looks about right to me.
Unfortunately thermal pads come in different thicknesses, so its going to be difficult to Guess which one would be right for this particular laptop.
Thanks new boy.
Yeah, I've no idea how to find out which one I need. Here's a couple of pics of what I have. 2mm thick perhaps?
Buy 1mm and stack if you need bigger...
Great stuff. I haven't looked yet but is there a particular product you recommend from OCuK? I'm assuming covering the vrams with thermal pads will help reduce my CPU and GPU temps?
No, it will just reduce the temps of the component it covers. So it will reduce the temps of the vram but not the core.
Any pads the OCUK stock will be good enough for this purpose really, just make sure you got enough especailly if you might be doubling up as Smffy sugguested
Surely you can measure the thickness of a unsquashed edge of the pad with a ruler? I did my laptop and replaced the pads with copper shims from ebay and got a much cooler laptop.
Yeah that would make sense to have measured it :p I've screwed the laptop back together again now. But from memory and looking at a tape measure, I think that it's more like 1.5mm thick.
