Upgrade advice
30 May 2007
Hello all just trying to help a friend upgrade his graphics card for him. He is wanting to play battlefield 1. Not sure what he currently has but his motherboard is a GA-990FXA-UD3 with a 850 watt power supply.
He is looking to spend between £300-400. Games at standard 1080 resolution.
Any help would be appreciated.
Cheers!
You could spent a fair bit less and still play Battlefield 1 maxed out. An RX 480 or GTX 1060 around the £250 mark would get the job done comfortably. He obviously has an AMD CPU, so that's going to hold a 1070 back a fair bit anyway.
Thanks for the suggestions. I have found out that he currently has a MSI HD 7950 3072mb GDDR5 and his CPU is an AMD FX-6 6300 Black Edition 3.5 ghz.
Cheers
I would advise him to upgrade the cpu first before adding a new card; he's probably already losing some performance in games due to the 7950 being held back.
What power supply is it, e.g. Corsair, Antec, Coolermaster?
Well, I can see two schools of thought here:
1) Wait for the next release of Intel/AMD cpus which I think are due quite soon (few months for Intel anyway, iirc).
2) Buy now. The following is just an example; there are plenty more experienced folk on here than I, so all I've done is selected good bang for buck components.
This is very similar (mobo + cpu) to what I've bought over the last few weeks. Very pleased with it. :)
https://www.overclockers.co.uk/giga...-6600k-bundle-10-pounds-saving-bu-026-gi.html
https://www.overclockers.co.uk/king...annel-module-black-hx421c14fb2-my-243-ks.html
https://www.overclockers.co.uk/cooler-master-hyper-tx3-evo-cpu-cooler-hs-034-cm.html
Some may recommend shelling out a little more on slightly higher frequency memory like 2400mhz + (which is what I bought).
Is he just gaming, or will he be doing video editing / rendering?
With a AMD FX-6 6300 I would get a 470(yes it will bottle neck but at least it is only 179 and not 600+) to tide him over or he will end up spending a lot of money up grading a motherboard and cpu and ram as well.
I agree with this.
RX 470 at maximum for an FX6300. Just too much bottlenecking otherwise.
And then they should plan for a major upgrade to Intel Kaby Lake or AMD Zen once they're available in a couple of months.
An FX6300 + RX 470 will still be ok for 1080p gaming, but going forward a full upgrade will be needed.
