just bought gtx 970
13 May 2008
hi guys I just bought gtx 970 to replace my old 580 gtx how much bigger is the 970? ive got a corsair 650 d case ? thank you
The dimensions are noted on the box of the card. Otherwise look it up the model on the manufactors webpage. The rest of us cannot help you unless we have specific details on brand and model. Also if size is something you worry about (no pun intended) perhaps you should have looked it up first before buying.
If you are concerned about the size of a GTX970 (you didn't state which 970 you bought, and they vary in size), why didn't you check before you bought it ?
