Hi all I recently purchased a bungalow with a condemned boiler and I'm having it replaced... I'm informed I need a new gas pipe (which I'm fine with), and the cheapest quote has said they're going to run it through the roof space. Other suppliers have suggested running it through the floor is preferred, Does anyone know anything about this subject?
British gas salesman (Note not engineer/fitter) suggested going through the roof void goes against the gas regulations?
My property is a 1 story bungalow with a roof space for storage and I would like the pipe to effectively go across the length of the house (from the garage to the kitchen)
Any help is much appreciated!
(note, any works will be by gas accredited installer etc, just the quote through the roof seemed a lot cheaper)
