Anyone have a Photon D270 + Pump Combo???
3 Jun 2007
Essex
If so have you by any chance used the top port as a inlet??
I have the adapter to change from M20 to G1/4 but whats baffeling me is how the hell do I fill the res??
some other models have two ports at the top but this only has one. So if I hard tube up the port how to i get the liquid in? Magic?
Grab a Y-split/T-split adaptor and wang it in the top of the res - one of these (or similar):
https://www.overclockers.co.uk/ek-w...litter-rotary-2f-1m-g1-4-black-wc-9d6-ek.html
https://www.overclockers.co.uk/ek-water-blocks-ek-af-t-splitter-3f-g14-nickel-wc-944-ek.html
And grab a ball-valve:
https://www.overclockers.co.uk/ek-water-blocks-ek-af-ball-valve-10mm-g14-black-nickel-wc-899-ek.html
Then you've got you loop coming into the splitter at the top with a closed ball-valve for filling/burping the loop (flexy tubing fitting, flexy tube and a funnel to fill the loop on the ball valve, pour in water and then close). Haven't checked the sizes for the above, and it's a tad inelegant, but it'd work.
Or find a t-tube fitting you can put on the hardline tubing going into the top of the res. They're a pita to bleed though are top fill res's with only a single hole.
I do have a ball valve and a spare 3 way splitter that i was going to put at the bottom of the loop to drain...
I may just use the bottom ports.. as you say will be a pain in the bottom to bleed the air out..
It's a pain in the bottom anyway. I have the 170 and the top of the light tube in it is only a few mm from the port so you need to be slow when you're filling.
I'd just use the ports on the pump.
100%. its a nice looking res, especially when you add the better D5 tension ring but the top inlet was very badly designed.
