- 12 May 2011
- Southampton
I've had my 2003 330ci for two years and done 18k on it (it's now at 106k). I've spent a fair amount on it and it has quite a few problems left over.
Fixed:
Clutch
Master and Slave cylinder
Starter motor
Handbrake (it seems to eat handbrakes)
Ignition coils / spark plugs on two occasions (it would misfire from cold)
Air leak (was an obscure valve the size of my thumb = £200 part).
water pump
Plus tyres, service 2, etc
A lot of this could and probably will go wrong on a £4k 6 year old focus of course, but it probably wouldn't be as expensive to fix!
not fixed
Burns 1l of oil every 600 miles
Central locking gone on passenger side
Cd player slightly iffy
Lumpy idle (probably spark plugs again; suggesting maybe an underlying problem as it seems to be eating them)
Rusty front wings
But then I sit on the motorway looking at everyone in their super bling looking but basic spec A3, golf, A class diesels, who drive like spanners, and feel superior in every way! And love the gentle transmission whine and smooth 6 cylinder power when I go from 40 to 70 in third. And I still look back sometimes (and not only to check the bloody locks). So it isn't just a pain in the arse, it does make you feel special, although it was my second car and I was coming from a 90s jap hatchback...
I think it's time is now coming to an end (with me) but it hasn't put me off my next misadventure, which is to get an 8 series
Edit:
I should probably do this...
Fixed:
Clutch
Starter motor
water pump
not fixed
Rusty front wings
Edit:
the beauty of the m54 is its so easy to work on.
So yeah, if you enjoy DIY or want to learn, the E46 is great to work on. If not, I'd probably avoid one.
And cheers!
