NFS@home challenge
OP
22 Oct 2010
Ratae Corieltauvorum
Are we up for this? starts in a couple of days. The project has a lot of 16e work units that need clearing. We could always just help the project out later and not join the challenge if it's too short notice.
12 Dec 2012
Milton Keynes , UK
If you are looking for 14e badge please serve yourself because we would like to reach 1000 14e (lasieved) factorizations by the end of the year. The ''Now Sieving'' should be completed as well as the ones in ''Queued''. I am processing C187_121_102 which is to be completed within 9 hours. Then I have reserved P223 (284688...)+1 which I don't know if I will be able to build a matrix because last time I tried to process it it was consuming more than 14GB of memory on my laptop!!!
Overall 300k 14e (lasieved) needs to be sieved by NFS@Home and then all of them post-processed in the back stage to achieve 1000 factorizations.
Carlos
PDW
PDW
21 Feb 2014
Carlos
You're gonna need a bigger boat :D
If they haven't all been done I'll come and help in December.
12 Dec 2012
Milton Keynes , UK
At Sam's request, NFS@Home will factor the smallest five Bernoulli/Euler numbers. Details of the project are at http://homes.cerias.purdue.edu/~ssw/bernoulli/index.html
These numbers are below.
Code:
c193 E,162  4433412106658741087933232089378724397906206646379922900251289622751707498087510521673827952479387101476055350479732960366249816761504231219756875500959872022188279008190800161931436720491245839
c198 N,228  296569147970687972018305992022305479444800534802596868167612154770357922331944290632711595707525008075052827152208842160028802232479554533007880867580604612496376331014306272671066168224885301922139
c200 E,192  38520071631718399385569612596870425832813667446322377950818788712501250551228139856601338294522891553906379588542169718154722596682565080979763328866848000587896648249672528064585979301197677287093573
c202 E,148  3288719081408570989091469257524004512856169702169344935878936181981622152040418051052138482890793620819361069696255059446484398066989546855559239020999441385627314503459380878410208878448073950298808719
c208 N,248  1832286501854003138052676989520560424403225562007684729403530852600313798697523554946311839528638518912406077110670650069044969139294389942454684694590767301444969837766981072288000680734361752459501676835073
Application is lasieve5f and more than 1.7M wus to be processed.
Carlos
