Hopefully it's just me being thick and NOT (another) issue with my boiler/cylinder D:
I'm trying to re-pressurise my system as it's dropped to about 0.5 bar and i'm HOPING that's the reason that the central heating is no longer working at all (hot water still works fine.. boiler is running fine with no errors either).
I've attached the filling loop, opened both valves and........ nothing!
Am i forgetting something?! I'm a bit paranoid to start fiddling with valves etc as I've got a bad track history with plumbing lol....
I'm assuming the 'stop valve cold water down service' valve is currently 'on' and should be left as-is?!
Any help appreciated
Thanks!
Filling loop attached (valves closed)
Pipes n... stuff!
Thanks!
Pipes n... stuff!
