Is the OcUK Tech Labs 240mm AiO liquid cooler decent?
25 Sep 2011
Staffordshire, UK
I recently bought a Thermaltake Water 3.0 Riing RGB 240 (£107).
The reviews were positive.
However, under Prime95 load, my i7-6700K (at 4.4 GHz) reaches 70C, which isn't much of an improvement over my Cooler Master Hyper 212 EVO's 80C.
Basically, a 10C decrease and a smaller case footprint is not worth £107, to me.
However, Minstadave pointed out the £55 OcUK Tech Labs 240mm Extreme CPU Liquid Cooling Upgrade Bundle to me.
Do you think that AiO kit will also bring the temperatures down to around 70C? If so, a 10C decrease over my 212 EVO and a smaller case footprint could be worth £55 to me.
I love mine, keeps my 5820k which is a hotter chip, running at 4.6 really cool.
Absolutely great value for money, bargain if you will
Personally, unless you simply must have an AIO for aesthetics, I'd look towards the Noctua NH-D15 or Cryorig R1 Ultimate... will perform better.
Cheapest I could find the Noctua NH-D15 is £76.
Cheapest I could find the Cryorig R1 Ultimate is £95.
They not only ugly (to me), they're more expensive than the OcUK AiO liquid cooler above (£55).
EDIT: OcUK charge £10 as the cheapest delivery method, bit steep, perhaps :( Better make that £65, then... :/
As a forum poster you should get free delivery (i believe the threshold is at 100 posts). make sure your OCUK account is linked to your forum account.
I tried to add "King Mustard" but it said something along the lines of "it has to be between 3 and 12 characters" or something.
theaterix / Minstadave,
Are you using the included Silverstone FQ121WC fans?
If so, are they both running at 1700-1750 RPM at all times? (basically, max)
Mine are, and it's definitely installed perfectly.
They're noisy!
Surely no computer fan is mean to run at 100% speed at all times unless they're cooling something that's overheating.
