- 18 Oct 2002
- Kuala Lumpur, Malaysia
We've been having issues with our Draytek router (2960) in our office dropping out recently and I've been trying to figure out what's causing it without much luck so far.
Each time it happens everything comes back within 30-60 seconds, but it occurs sometimes once an hour, sometimes only once or twice a day. I work remotely so my VPN session (usually just RDP) drops as well.
The WAN connection itself is fine - VOIP which runs through the same connection (but not this router) stays up, the Draytek can't be pinged during these short outages either so I'm sure the fault is there.
There is no activity on the logs during these drops, only a few of the below entries each time (just with different IPs of course)
[ip_route_input_slow:2426] set reply 31.13.92.14192.168.40.18 oif=13 and NO ROUTE
Manufacturer support hasn't been of much help so far, and I haven't been able to find much on Google either.
FWIW, CPU and Memory load aren't high (<50% mostly), only myself connected through VPN. Restarting the router doesn't help unfortunately.
Any ideas? I hope I'm at least on the right track and those log entries are related
