Permabanned
- 25 Oct 2004
So my clutch is playing up, gears engage fine, clutch doesn't slip but the pedal when depressed to the floor for more than a few seconds will stick, you can manually bring it back up again and change gears just fine but if you depress it for more than a few seconds it will stick.
Changing gears rapidly, as in pulling away and going through the gears as you accelerate doesn't cause an issue as the clutch pedal isn't down long enough to stick.
slave or master cylinder duff I take it. Any ideas on possible cost for a 2002 honda accord 1.8i
Had a look around and see no sign of leakage on the master or slave cylinders and fluid levels have not changed.
