- 16 Oct 2008
Motherboard is an Asus Z87 Deluxe all Hard drive (Samsung 840 Pro's x 2 for OS and WD Black & Greens) work fine on the 6 Intel ports but when i connect drives to the ASMedia ports things start to play up and by this i mean system takes ages to boot, so i have disabled these in the bios and bought a Adaptec 7085H Host Bus Adapter however i need to connect another 4 WD Blacks to this card and was wondering what is the best configuration for doing this, I do have the relevant SATA cables for both ports meaning i can connect up to 8 drives but for at least the next 6 month i will not be adding any more drives.
So what is the best way to set this up, should i bung all 4 drives on the first channel or split them 2 & 2, if 2 & 2 should i alter the port number so 1st channel 1 & 3 ports and Channel 2 ports 2 & 4.
Just for your info i have nothing in any slots as video comes off CPU (i7 4770k) but i will be putting card into the 2nd PCIe 3.0 slot which is the middle of the full length slots, here is a quick image of the mainboard.
Board image here:https://www.asus.com/websites/global/products/9QxiE6DZEdR1sou1/line.jpg
If you need any other info from me just ask.
All1
Please don't link to competitors, and don't hotlink to images. If in doubt please re-read the FAQ - Thanks, Armageus
All1
