- 8 Sep 2010
- Kent
Hi.
I'm currently running an LX5090 TV with the OEM soundbar which is hooked up through stereo speaker wire connectors. It sounds great, but the thing is really loud for late night viewing and i find myself making adjustments on the remote constantly for the sake of my housemate. This really pulls me out of what I'm watching. I want to have a set of decent cinema headphones that I can turn to in the midnight hour but need some advice on the connectivity and equipment I need.
I've tried plugging into the headphone port on the side of the TV but that obviously cuts out the soundbar sound and I don't want to have to keep plugging and unplugging connections. By my deductions, that leaves an optical out which will run to a headphone amplifier. I've tried a cable in the port and it leave the soundbar output intact but i don't have anything to run it to at present to be sure that it won't be an issue once it's all eventually set up.
Have any of you had experience with this? Will it cut out the TV sound or work independently? If this will work, can you recommend a decent amplifier and set of headphones?
