So I decided to build an external GPU for my macbook pro 2015. I used a setup recommended by a website called egbukitproject.com which shut down shortly after I ordered all the components. I Spent about ~£450 on the products below:
- Zotac GTX970
- Akito Thunder 2 PCIe adapter
- EVGA 500W psu
- Thunder 2 cable
- PCIe 16X Male to 16X Female Extension
I installed the latest version of Windows 10 using boot camp assistant but when I used the relevant driver software, it doesn't register that there's a gpu connected. No fans spin on the psu or gpu, no lights come on - basically there's nothing to suggest that they're even turning on. I was told by a friend that the psu might not start without a kick from the motherboard; either that or it's broken entirely (although i bought it new so that's unlikely).
Skip to 16:10 in this video - that's pretty much exactly what I did.
Any help/suggestions are welcome! Thanks!
			- Zotac GTX970
- EVGA 500W psu
- Thunder 2 cable
