- 28 May 2007
Can't agree there - in some ways there isn't a clear winner as the propitiatory/closed system nature of G-Sync tends to be a significant negative over some of its potential advantages but at the same time G-Sync has some not insignificant technical merits (proper handling of games and programs that don't use exclusive fullscreen, etc.) that FreeSync lacks especially now if you have FastSync + G-Sync working properly together. Having used both even without any bias one way or the other there is no way I'd choose FreeSync over G-Sync if I had to pick one for every day use.
I believe Freesync works in windowed mode when using dx12. This might be a problem now but one that will most likely disappear. It's a little like Crossfire/Sli in dx11 as crossfire does not work in windowed mode but i believe in Multi Gpu dx12 it does. Dx12 seems to fix a lot for AMD tbh. I don't know why they can't get it working in dx11 but it would have been a plus if both these techs did.
