how to copy and paste?
30 Dec 2009
Wigan Lancs
On my 2015 iMac running Sierra i have inserted a USB memory stick but i can't paste on to it for some reason.
So on my desktop i have a file i downloaded and the USB Disk icon is there if i open up the USB Disk then try to copy and paste or drag and drop the downloaded folder to the USB disk nothing happens.
If i right click the USB Disk icon and click on Get Info, under sharing and permissions at the bottom it says i can only read.
How do i make it so i can write to it as well?
Thanks
Thanks
What is the file format of the USB stick?
http://www.howtogeek.com/73178/what-file-system-should-i-use-for-my-usb-drive/
I have no idea to be honest. Could it be the fact I've. Even using it on a windows system and that's the problem, do I need to format it on the iMac?
