Man of Honour
- 11 Dec 2002
- Darkest Norfolk
I've got a pagoda build to do next week and instead of doing it all by hand I've got signoff from SWMBO for a powertool to cut my fingers off down on time & effort.
I'm using pressure treated softwood and need to make the following cuts:
8 of the 45degree cuts in 100x100mm timber for braces
8 of the L shaped cuts, 50mm deep, by 150 high into 100x100mm vertical posts
15 notches sized 50x50x50 into 150x50mm rafters
7 30 degree (ish) slants on the front of the rafters
basic design is as follows:
I have a workbench, clamps, set square, hand saws, chisel set and a few other bits but wondering about getting one of the following:
what do you recommend?
- A mitre saw (although i'm not sure i can get one that'll cut the 100x100, even part way through due to clearance.
- A hand held circular saw - again won't do the deep cuts, but can make them easier
- Reciprocating saw - should do all the cuts but pretty easy to mess it up as its hand held
- Oscillating multitool - would make cutting the 50x50x50 notches much easier, but pretty useless on the rest of it
