Ive had a look at the games I play I don't think its supported for just cause 3 but haven't played that in a while. the other games it is supported.I have been using SLI 970s since launch (2yrs+) and for 1440p it's pretty good. However, not all games support it well or at all so you may want to check how your favoured games perform first. Personally I wouldn't want to this late in the 970 cycle unless you can pick one really cheap![]()
yea for what ive seen in benchmarks the Sli 970's score around the same as the 980ti but at least you don't have the sli problems in games.I would stick with plan a and keep looking for a 980 ti
For 1080p is would be fine, for 1440p not a chance.
I wouldn't if I was you.
Back in the day I wanted more power so doubled up on my 670. It was good in sone titles but most of the time it was loud, hot and came with its own issues.
Then you've got the beam problem. Two 970 is still only 3.5Gb of vram.
Save up and get a 1070 if you want an upgrade.
