Hi,
I would like to introduce a new section on our website that we have recently started to implement for basically action cameras and dash cams. After a couple of manufacturers decided to take on a few new projects we have also decided to list the products. You can view the whole range on the link below.
https://www.overclockers.co.uk/peripherals/input-devices/action-dash-cameras
we have been testing the asus dash cams over the last couple of weeks to see if they are up to the standard that the we hope for here. the asus models where kindly provided for us to test and they have not disappointed.
as you are aware there a lot of cameras out there for ridiculously cheap prices saying they are 1080p but rarely live up to the description.
i will focus on the asus models as we had them to test so we have a little experience with them.
the asus reco classic is the entry level model but it is far from the lower quality that you would expect from the entry grade. the camera quality is very good as shown below in the videos and it is very easy to use and setup. all the settings are setup to use all the features of the camera but can be turned off with ease in the menu when ever you wish. the image that the camera records in is 1080p and the high quality recording is apparent when played back. it has a 140 degree viewing angle as well so covers a lot of the front view of the car. the only downside to this camera for me is that it does not come with an sd card which is disappointing seen as the camera has no internal memory but not to worry though we are giving you one for free.
the asus reco smart is the higher model which can not only be used in car as a dash cam but is also portable so you can take photos and videos on the move. the reco camera has some slightly better internals than the classic model with its upgraded camera sensor to improve image quality and a wifi chip to allow you to contact to the reco app. the app is a big part of the product as it allows you to stream and preview videos at anytime. the app has basically replaced the on camera display to allow the internals to be better and allow real time streaming on the app. the real time streaming is mainly beneficial for when you use the camera as portable device but it does allow you to look back on videos at any point.
both the cameras have gps tracking as standard so if you were in a crash the cameras detect that and hard lock the video so it can not be wiped. the gps tracking also shows and stores the exact coordinates the crash happened.
i have attached some videos below to show some unboxing and a few clips of the cameras in use. these are done by glyn so that we can show our personal experience and hopefully show the cameras off in use rather than just going off manufacturer details.
videos:
asus reco classic unboxing + footage:
asus classic footage:
asus reco smart unboxing + footage:
dash cameras
Asus Reco Classic 1080p Dash Camera @ £99.95 inc VAT https://www.overclockers.co.uk/asus-reco-classic-1080p-dash-camera-hd-03j-as.html
1080p Resolution, Wide 140 Degree View, HDR Technology, G-sensor
Specifications:
- Chipset: Ambarella A7L Series
- Aperture: F2.0
- Screen: 2.0” LCD
- HDR (High Dynamic Range): Yes
- G-Sensor: Yes (3-axis accelerometer)
- Storage: Micro SD SDxC, class 10 (8G~64G)
- Resolution: Full HD 1080P (1920*1080); HD 720P (1280*720)
- Video file format: MOV (AVC/ H.264)
- Video file length: 5 min/ per file
- GPS: External GPS sensor
- Speed camera detection:Yes
- Power / Adapter: Cable for cigarette vehicle adaptor (four meters)
- Operation Temperature: 0~65C
- Storage Temperature: -20~70C
Package Content:
- Car cam
- Cable for cigarette vehicle adapter
- GPS mount holder
- Quick Start Guide
Only £99.95 inc VAT.
ORDER NOW
Asus Reco Smart 1080p Dash/Portable Camera @ £159.95 inc VAT https://www.overclockers.co.uk/asus-reco-smart-1080p-dash-portable-camera-hd-03k-as.html
1080p Recordings, Versatile, Real Time Viewing, 150 Degree View, Instant Previews With App
Specification:
- Main Chip: Ambarella
- Sensor: SONY CMOS Sensor
- Aperture: F1.8
Features:
- NFC activate Wi-Fi and the ASUS app with just one touch
- ASUS Reco app allows for instant previews, downloads, and sharing on mobile devices via Wi-Fi
- Emergency file back-up and 500GB of ASUS WebStorage free for one year
- Wi-Fi Technology: Wi-Fi 802.11b/g/n
- Collision Sensor: G-sensor
- Battery: 720 mAh
- Storage: 8 GB ~ 32 GB Class 10 micro SD card
- Resolution: Full HD 1080P (1920x1080), HD 720P (1280x720)
- Video: .mp4( AVC/H.264)
- GPS: External GPS mouse (On selected models), External GPS sensor (On selected models)
- Power: 5V/1A
Package Content:
- Car Camcorder
- Car Charger
- GPS mount holder
- Quick Start Guide
- Self-adhesive cable clips
- Micro SD card
- Filter
- Dual USB car charger
- 4 meters USB cable
Only £159.95 inc VAT.
ORDER NOW
RAC ProofCam 4.0 MP Super HD Rear View Mirror Dash Cam - 1296p - Black @ £149.99 inc VAT https://www.overclockers.co.uk/rac-...ew-mirror-dash-cam-1296p-black-hd-000-rc.html
Super HD rear view mirror dash cam, Speed camera alerts, Lane safety system, Built-n GPS tracking, 4.3" TFT Screen,
Specification:
- Dimensions: 32 x 3 x 8.55cm
- Battery life: 20 minutes
- Weight: 0.447kg
- Screen Size: 4.3" TFT LCD (1440 x 272)
- Field of vision: 150°
- Built-in GPS Tracking: Yes
- Speed Camera Alerts: Yes
- Lifetime Camera Updates: Yes
- Recording Quality: 2340 x 1296 Super HD
- Memory Card: 8GB included - supports up to 64GB microSD class 6 to 10
- Parking Mode: Yes
- Enhanced Night Vision: Yes
- Photo Mode: Yes
- Google Map Support: Yes
- Lens: 6G + 1IR lens
- G Sensor: Yes
- SOS Data Protection: Yes
- Mount Detection: Yes
- 360° Cradle: N/a
- Forward Collision Warning: Yes
- Lane Departure Warning: Yes
- File Locking: Yes
- Loop Recording: Yes
- Sensor: 4 megapixels
- Image Resolution: 16 megapixels
- Video Format: H.264
- SOS Recording: Yes
- Distortion Correction: Real Time Geometric Distortion Correction (de-warp) Filter
- Low Light Warning: Yes
- Tone Mapping: Yes
Only £149.99 inc VAT.
ORDER NOW
RAC ProofCam 4.0 MP GPS Super HD Dash Cam - 1296p - Black @ £119.99 inc VAT https://www.overclockers.co.uk/rac-proofcam-4.0-mp-gps-super-hd-dash-cam-1296p-black-hd-001-rc.html
2.7" TFT Screen, GPS Tracking, Super HD recording, Forward Collision Warning, Over Speed Alarm, 150 degree view.
Specifications:
- Dimensions: 10 x 3 x 5cm
- Weight: 0.196kg
- Screen Size: 2.7" TFT LCD (960 x 240)
-Built-in GPS Tracking: Yes
- Parking Mode: Yes
- Photo Mode: Yes
- Lens: Full 6G + 1IR lens
- G Sensor: Yes
- 360° Cradle: Yes
- File Locking: Yes
- Tone Mapping: Yes
Only £119.99 inc VAT.
ORDER NOW
Action Cameras
Billow XS360 360 Degree Action Camera Red 1920x1440 (30fps) 16MP Waterproof WiFi Mic and Speaker LCD @ £119.99 inc VAT https://www.overclockers.co.uk/bill...proof-wifi-mic-and-speaker-lcd-wc-003-bw.html
WIFI, 220º Fish eye ultra wide angle lens, 1920x1440 P (30FPS), LCD, 30M WATERPROOF, SD UP TO 32 GB, 16 MP Camera, MicandSpeaker, COMPATIBLE WITH YOUTUBE 360ºVIDEOS
ORDER NOW
Billow XS360 360 Degree Action Camera Black 1920x1440 (30fps) 16MP Waterproof WiFi Mic and Speaker LCD @ £119.99 inc VAT https://www.overclockers.co.uk/bill...erproof-wifi-mic-and-speaker-l-wc-002-bw.html
Was [OLDPRICE] Inc. VAT
ORDER NOW
Billow XS500 Action Camera Red 1080p 12MP Waterproof WiFi Mic and Speaker LCD @ £64.99 inc VAT https://www.overclockers.co.uk/bill...proof-wifi-mic-and-speaker-lcd-wc-001-bw.html
WIFI, 170º ANGLE SUPER WIDE ANGLE LENS, 1080P RESOLUTION, 2" LCD, 30M WATERPROOF, SD UP TO 32 GB
Only £64.99 inc VAT.
ORDER NOW
Billow XS500 Action Camera Black 1080p 12MP Waterproof WiFi Mic and Speaker LCD @ £64.99 inc VAT https://www.overclockers.co.uk/bill...proof-wifi-mic-and-speaker-lcd-wc-000-bw.html
ORDER NOW
View all Lifestyle and Gadgets Here
videos:
dash cameras
Specifications:
- Aperture: F2.0
- Screen: 2.0” LCD
Package Content:
- Car cam
- GPS mount holder
- Quick Start Guide
ORDER NOW
Specification:
- Aperture: F1.8
Features:
- Battery: 720 mAh
- Power: 5V/1A
Package Content:
- Car Camcorder
- Car Charger
- GPS mount holder
- Quick Start Guide
- Micro SD card
- Filter
ORDER NOW
Specification:
- Weight: 0.447kg
- Parking Mode: Yes
- Photo Mode: Yes
- G Sensor: Yes
- 360° Cradle: N/a
- File Locking: Yes
- Tone Mapping: Yes
ORDER NOW
Specifications:
- Weight: 0.196kg
- Parking Mode: Yes
- Photo Mode: Yes
- G Sensor: Yes
- 360° Cradle: Yes
- File Locking: Yes
- Tone Mapping: Yes
ORDER NOW
Action Cameras
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
