Phantek Evolv ATX
Man of Honour
17 Feb 2003
Chelmsford
Has anyone else got a custom water cooled loop setup in this case? I'm not sure if it the steel but it seems to be amplifying the noise inside.. My D5 pump was never this noisy in my older build?
Thoughts?
Mine was a bit noisy to be gin with due to the location of the pump and a lack of anti vibration material where one edge was touching the case but once I sorted that out it is fine.
Where have you got the pump installed?
I've got it installed as part of the D5 photon 170 res. Is attached where the front HDD areas..
here's a picture.
There's a small gasket between the back plate of the pump/res
Pump speed is on 2..
Hmm well at level 2 it really shouldn't matter how it is attached as it should be all but silent. Are you sure it is the pump and not one of the HDDs below it?
