the heat shrink butt connector type
is it safe to assume if the cable fits in to the connector then its fine to use? it's for rear lights on a trailer
got a pack with blue red and yellow, the wire fits inside the red ones no problem, except the earth as its a bit thicker
any time I've seen them used on repairs/mods etc it's always the blue or yellow ones, can't remember seeing the red ones
wondering if there's a reason or if the blue ones are just cheaper/popular
