Should I make use of my spare USB type C port at the rear of my pc on the motherboard ? (Windows 10).
I was wanting a HUB that can get the best 'Type C' speeds going to the usb 3.0/3.1 hub which has to have maybe at least 4 x usb 3.0/3.1 ports and backward compatible with usb 2 , thing is though, have you seen the stupid little 10 inch cable or whatever the size is that seem to be the only things available on Type c to 3.0/3.1 hubs ?
Its crazy man
, for starters, my pc sits away on the corner of the desk/table, I am approx 5ft from the rear of the pc when I am sitting at the pc.
I need or rather want the actual hub to sit just next to my keyboard infront of me, ideally with a longer cable going from the hub under the table and then up through a hole custom drilled for cabling infront of the keyboard for such things as a hub etc.
There are a few things on the market online but I am so mixed up and confused with hubs, cables, adapters etc as you may know about I hope someone does ?
Can someone please help me and suggest some things please ?
Thanks guys.
P.s, or am I just better to get a usb 3 hub with longer cable and forget the faster and better Type C port altogether for maybe a couple of years ? seems a bit of a waste though, hmmm
 , I dont know man
Its crazy man
, for starters, my pc sits away on the corner of the desk/table, I am approx 5ft from the rear of the pc when I am sitting at the pc.I need or rather want the actual hub to sit just next to my keyboard infront of me, ideally with a longer cable going from the hub under the table and then up through a hole custom drilled for cabling infront of the keyboard for such things as a hub etc.
Thanks guys.
 , I dont know man
