1070 or 1080
22 Oct 2004
As title I'm thinking of getting one of the above cards for my 3440x1440 monitor.
I've narrowed it down to:
EVGA ftw hybrid 1070
EVGA ftw hybrid 1080
Asus matrix RGB 1080
Is a 1070 good enough for any game at 3440x1440 with no gsync. I rather buy the higher end card if it's going to give me 60fps and not having to turn settings down. But then I don't want to be wasting money on getting stupidly high fps that I won't see.
Go with a 1080 over a 1070 for that res, I swapped out my 1070 for a 1080 when I changed from the 27" tn swift to the 34" wide Asus rog swift as the 1070 was on the edge of acceptable performance with some games at the higher resolution
As others, 1080.
I have the 1080 and a non Gsync widescreen. As I'm a graphics whore, all sliders get turned up and apart from a small handful of games, very few actually gets to and stays on 60fps.
Hold your nose at the cost and just get a 1080. Really, just do it.
Okay thanks I'll go with a 1080 and be done with it, I really don't want to be upgrading for about 3 years.
I'm gonna go with the EVGA ftw hybrid over the Asus one due to space gonna be a bit tight in my itx build. The Asus card would still fit but it'll be close.
So should I get the EVGA card or am I making a big mistake over the Asus card?
I've got a 1070 with 3440 x 1440, and it's 'acceptable' for 60 fps in most games.
Given the budget though i would get a 1080 :D
I'm deciding whether to buy my CPU first and put my Titan black into the new PC and it'll be all up and running. But then I'm not in a massive rush and I could buy the card and then CPU in early December with the new PC how I want it.
Also how much better is a 1080 compared to a Titan black?
what cpu?
You have a 4790k already....
