Advice on consumer rights for a damaged oven after cleaning service
Man of Honour
12 Jan 2003
UK
Hi guys
About 2 months ago I had my oven "professionally" cleaned. They did a very thorough cleaning job and we were pleased with it. At the time of the clean the guy had a really hard time fitting the door back on (that he'd removed for the clean) and forcefully had to put it back on after about 15 minutes of hard work.
The oven was used for the first time after the clean the following day, and after being on for about 40 minutes we heard a loud crashing/smashing noise from the kitchen. Thankfully no one was in there, but the whole oven door had shattered and the front handle had come off. This was the first use after the clean and the oven had been totally fine beforehand for 4 years when it was brand new.
The door was not shattered on the inside so it seemed to be related to his forceful re-attachment and struggles with the door (as opposed to any chemical related explosion).
The cleaning company were contacted about the issue and the manager there said he would look in to it although clearly seemed to oppose any idea they were to blame when i spoke to him. Photos were sent of the oven door inside and out. Since they do not do repairs or anything like that we agreed that i would arrange a repair through the oven service team/manufacturer and let him know the charge which could then be discussed. That ended up costing about £190 total for a new door and the visit.
The engineer who fitted the new door put in his report (which we got after the visit on email) that the door had shattred due to an "incorrectly inserted locking pin". clearly identifying the re-fitting of the door as the culprit for the damage, which isn't a surprise given the force and effort used by the cleaner to re-fit it. That engineer report was passed back to the manager at the cleaning company as well.
The last i heard from him was over a month ago now when he said he was completing his "investigation" and would also speak to the service engineer. I've chased him 3 times since for an update but heard absolutely nothing. I suspect they are trying their best to dodge all responsibility here even though it's pretty clear that the damage was a result of their work!
Where do i stand here? what should i do as a next step if i continue to hear nothing from them? any advice welcome :)
Recorded delivery letter to them giving two weeks to pay otherwise start small claims proceedings.
Speak to local trading standards, they will more or less dictate a letter for you over the phone quoting the relevant clauses of you statutory rights. You basically need to go down the time is of the essence route giving them a reasonable length of time to rectify it before you take it further. Once you've done that, along with a 3rd party report then small claims, I would think would be a formality. Deffo speak to TS, they will give you a reference as well which I like to note in my letters to the company as they tend to hate TS being involved.
Small claims but if they don't settle expect it to potentially go to the court of their choice, going through this with someone at the moment and we're having to attend court in London, despite us being in Scotland.. mucho fun :-/
Hi guys
As others have mentioned, threaten to take them to court and start off with a letter before the court claim. I'd start here:
https://www.citizensadvice.org.uk/c...action/step-one-write-a-letter-before-action/
Was definitely effective in finally getting compensation out of some wholeheartedly inept builders that were dragging their heels for months.
Look into something called a 'Notice before Action'. It is basically a letter that says if you don't respond a summons is coming your way. Advice I have read before is that the courts can take dim view if you don't send one.
can you post photos on here? i run a cleaning company, and oven cleaning is one of the things we do. might be able to give an opinion to how it would have happened. chemical damage is almost 0% of this being the cause.
What on earth are they doing if they can't re-fit an oven door properly.
believe it or not, some oven doors are just designed so terribly that they make it almost impossible to put them back together. One type i hate with a passion is where you have a smaller panel of glass on the inside of the door that's got a seal going round it and held in by 1 screw either end. most are ok, but some it's almost impossible to put the glass back with the seal around it, as the action of putting it back in place causes the small rubber seal to rub off.
Oven doors aren't usually that expensive. in the 7.5 years we've been cleaning ovens, only one door broke. turned out not to be out fault , but the easiest more sensible thing to do is pay for the replacement and replace it too.
If i were the OP, the first thing i'd do once this was over and done with, is leave a bad review online with photos as proof. Breaking something by accident is one thing, but to run and hide from the issue is terrible on their part.
Have I missed something here.
You had somebody from outside your household come and clean your oven for you? :eek:!
Really??
Sorry!
I know I am, nearly sixty, but really!
Maybe I should move to Montana before it is too late. :confused:
The Zombie apocalypse is clearly upon us! :( :( :(
Really??
Sorry!
Why is it a hard thing to grasp? People have different priorities than spending a good portion of their day cleaning their oven. Especially when they have the financial means and I'm assuming other responsibilities that they feel would be better suited for their time.
Really??
Sorry!
since this...
https://www.instagram.com/p/0m8_lLGs00/?taken-by=mayergroupuk
turns into this....
https://www.instagram.com/p/0m9GUTGs08/?taken-by=mayergroupuk
for £49.50.
you go to work, come home and find your oven looking brand new. most only get them done once a year and the results are fantastic. it's a joy to use a brand new looking oven that someone else cleaned for you.
I suppose it is a different generation thing.
I simply cannot think of any job that I was able to do for myself that I ever thought of getting somebody else to do for me.
It is simply something that would not occur to me.
The things that I might need to do for myself, I just do because it needs to be done.
