All in all I get the following MPG (Fiesta 1.0T) Official figures put it at 65+ MPG, which is insane.
Not really insane, you are driving at speeds that are beyond those which will achieve those figures.
I managed 65mpg from a 1.6 TDI Octavia recently. Try harder![]()
Getting good economy is a skill, and a very rewarding one, but you have you change your paradigm from one of "I need to get there in the shortest possible time" to "I want to drive as efficiently as possible".
The rewards can be significant fuel savings at a cost of usually no more than a few minutes on your journey.
Leave a bigger gap, coast as much as possible to minimise braking, try to avoid braking at all costs (if you brake when you could have coasted you were on the gas too long). Read the road ahead, anticipate 15 seconds ahead not 4 seconds...
Gentle acceleration, block changes, yada yada, you can easily turn a 55mpg car into a 75mpg car when you learn the behaviours.
I drive a 1.5 Mitsubishi colt and get 55mpg (Petrol) which I am pretty happy with.
While 'extra urban' sounds like it should mean a long motorway trip it really doesn't.
http://www.dft.gov.uk/vca/fcb/the-fuel-consumption-testing-scheme.asp
Also as the tests are done on a rolling road in a sealed environment with no wind resistance, steering movement and sometimes special oils in the engine to reduce friction it really doesn't represent anything like what you should expect in the real world.
As for 1.6 vs 2.0 in reality you can find the bigger engines to be just as fuel efficient in some conditions, sometimes the bigger engine will have taller gearing meaning its running a few less RPM for a given speed which can have a bigger effect on MPG than the slightly increased capacity.
I tend to up-shift gears slightly quicker than the dash requests -- maybe that's part of it.
Trueplus the big hills around here don't help.
Indeed.
Hypermiling can be quite fun, And even not, very financially rewarding.
(Surprisingly, for long journeys, the LC is actually one of the more economical vehicles I have ever owned. Only the R5 campus was better)
I recently had a 2.0TDI Octavia for a 320ish mile round trip which included a couple of days of city commuting and heavy traffic on the M42 (both directions). It easily managed 71mpg so not sure what you were doing.![]()
I usually get between 19 and 21 mpg to a tank, so just be happy![]()
Same.
The EPA figures are pretty accurate though - 11-15.5 l/100km and I get very close to 11 when doing just "highway" mileage, and average around 14 l/100km (20mpg) day to day (mostly in town).
We were discussing this the other day. All things being equal (same engine tech, gear ratios, vehicle weight and terrain etc) I'd assume fuel consumption is fairly linear despite engine size. i.e. a 2L engine needing to rev to 3000rpm to sustain 70mph will use the same amount of fuel as a 4L engine only needing 1500RPM?
We were comparing three vehicles (different makes, sizes etc, but all petrol) and looking at RPM at a set speed (around 70mph) and the rpm differences were fairly significant. One vehicle rarely goes about 2000rpm (sits at around 1200-1700 usually) for anything but flooring it, whereas the other spends its time at around 3000rpm just around town and the least fuel efficient sits in the middle (middle sized engine) and sits at around 2500rpm
As has been said, drop to 60.
On the motorway? Enjoy those artics overtaking you as close as possible.
Really annoys me this, as you doing 60 forces large vehicles into the middle lane just to keep their momentum up and thus turning a 3 lane road into a 1 lane for 30 secs minimum, and repeatedly, until the truck(s) gets past.
Just to save a few precious pennies.
HGV's are speed limited between 52 - 56mph, doing 60 in most - certainly Volvo's & Scania's - will gain the driver an "over speed infringement" on his tachograph, not to mention you'll only exceed the limited speed on downhill sections - over run - when carrying a fairly considerable load weight.
So long as cars don't drop below an accurate 60mph (bearing in mind tachographs are calibrated whereas speedometers in cars aren't) then you shouldn't cause a problem to larger vehicles and still save a bit of juice,don't get me wrong, not much annoys me more than a car doing ~ 50mph especially when they usually speed up once the truck tries to pass them, but, should you bear in mind my points then your annoyance should be unjustified.![]()
Interestingly in engineering terms the reason a smaller engine is supposedly more effecient is due to the "pumping loop" ie a big engine running at a low load will be "sucking" against the throttle obstruction, as engines theoretical effeciency is actually highest at full bore.
However when you try to translate this to the real world people want to go fast sometimes and a small engine obviously doesnt have the grunt unless your driving miss daisy, to get around this they turbo everything now so you have grunt when you need it.
Issue is, because people want to go faster they just floor it anyway so it defeats the purpose.
I'm not a fan myself, for simplicity's sake i'll take the fabia:
Mk1 was a 1.9 tdi at 100bhp, mk2 was the same from a 1.6 and the mk3 is the same again from a 1.4. now sure this means better theoretical effeciency, and the lab tests prove it, but what it means in the real world is you've moved from a relatively smooth power curve where its not that obvious when the turbo kicks in to an engne thats just dead until you give it enough welly then suddenly it takes off.
