I was going to post this in the Audi thread, but this post is more about detailing cars than the actual type of car.
I've always liked keeping my cars clean and I've always washed and polished them religiously. When I was young I used to enjoy cleaning my Dad's cars until I was old enough to drive and get my first (a gold Renault Fuego). Dad used to say I washed it so much the paint would start coming off. Wouldn't have been a bad thing considering the colour.
These days I don't seem to have the same amount of time or inclination to be on my hands and knees, cleaning and polishing. However I found a local chap who can do all this and better than me.
After seeing the amazing results achieved by correcting the paint on my previous year old Alpina D3, I've gone a little further this time and had my new daily - the little a3 - detailed and a ceramic coating applied. I thought this stuff was similar to SupaGuard so dismissed it entirely, but hearing positive opinions I thought I'd give it a go. Should protect my paint from salt over winter (should be good for up to 2yrs apparently) and make it much much easier to wash. I'm very happy with the result, the car looks amazing, probably how it should have done when I picked it up at the dealership. Time will ultimately tell if the coating makes a massive difference.
I know there are some detailing freaks on this forum, has anyone else tried or thought about trying a similar coating?
The blurb:
GYEON Q2 MOHS+ lays down a structurally denser layer of inorganic and organic components that cross-links very strongly with painted surfaces, forming a semi-permanent protective coating that is impervious to cleaning chemicals and natural solvents. Indeed, this coating is actually hard enough (and thick enough) to significantly improve the scratch resistance of treated finishes, with each application typically adding four grades of hardness to the finish on the Mohs scale.
In addition to the chemical- and scratch-resistant properties outlined above, GYEON Q2 MOHS+ also provides excellent levels of protection against bird droppings, bug splatter, road salt and harmful UV radiation for upwards of two years at a time, even on cars used as daily drivers. Furthermore, it also causes treated surfaces to become both water hating (hydrophobic) and oil-repellent (lipophobic), which gives rise to a strong self-cleaning effect. This means that your car will stay cleaner for longer in between washes, and will acquire fewer bonded contaminants (e.g. tar spots) over time.
https://flic.kr/p/NfgaB7
https://flic.kr/p/NfgaRf
https://flic.kr/p/NWnsBJ
https://flic.kr/p/NWnsqG
The blurb:
