Man of Honour
- 12 Jul 2005
- Aberlour, NE Scotland
I tried push/pull on both my rads and it gave me very little in the way of lower temps but a lot more fan noise. I am now running push on both rads.
That's brilliant cheers guys.
Are you all on push pull, push or pull?
My front rad will be push and my top rad will be pull.
That's great, cheers guys.
So I should be ok with my bequiet silent wings 3 1000rpm edition then. Just need 2 more then I'll have 5 in total.
What are your pump speeds at and do you have them adjust to the temp or just run a fixed rpm?
Your build is gorgeous mate!
Fans off unless gaming. All on max if gaming. Simple.
What temps are you getting at idle?
Do you use a fan controller to achieve this?
