bit of mathz problem?
9 Dec 2006
@ManCave
i woke up with a very weird math calculation but no idea why
if santa claus gets around the world in 1 night
how far does he travel in miles?
how fast does he have to go in mph?
anyone fancy giving it a try? :p
Circumference of earth: 40,075 km
1 night: 8 hours
Speed: 40,075 km / 8 hours = 5,009.375 kph or 3,112.6813161 mph
This is not at all accurate though.
the only way i could think of working it out was get sq/m of each contient then add them together.
as he has to go vertically too..
There is a very good argument against it being "maths" over "math".
Usually I'm on the side of anything against Americanisation of words. however the argument is this.
You should never pluralise a shortened word.
Maths is short for mathematics, the word can be shorted to math by you should not then add an "s" to the end.
1 night: 8 hours
Its not a straight line though. He will zig zag from house to house. Its likely to be multiple times larger.
Plus the amount of time he spends accelerating/decelerating safely will decrease the amount of time he can spend at the top speed.
Well I never knew that. Thanks!
You'd have to know the location of every house visited (good children only obviously), and then understand the heuristic he follows for route planning. Traveling Salesman? Or does Santa apply his own graph traversal algorithm?
If you then model the graph of houses, and the path taken, the edge lengths will provide the total distance traveled.
The time he has to complete the task is interesting. Does he only work during sleeping hours? Bit akward if he pops down the chimney during lunch on Christmas eve. I would presume he would follow a 'follow the moon' approach, ensuring he starts at UTC-12, and then works progressively West. We'd have to factor in the distance from the North Pole, to the first house, and so on.
Poo breaks?
There are roughly 2 billion children worldwide. However, assuming Santa doesn't visit the children of Hindu, Muslim, Jewish, atheist and so on parents, that leaves the 35 per cent or thereabouts whose parents consider themselves Christian. That's still an impressive 700,000,000 children in a night. Assuming three children per household, that's 233,000,000 stops for Santa and his sleigh.
If we assume that the 233,000,000 good Christian households are distributed evenly around the world , and the planet's surface area is 510,000,000km (and for the sake of simple calculations we are going to treat the Earth as a square map, rather than a globe), then each stop between households will be around 1.47km (0.91 miles) apart. Santa will therefore have to travel a total of 342,510,000km (212,030,000 miles).
If he's clever about it, and travels from east to west with the Sun, maximising his available night-time, Santa has about 32 hours to work with (assuming children sleep for eight hours, he has 24 hours plus those eight to finish). Travelling 342,510,000km in 32 hours equates to a speed of 10,703,437.5km/hr (6,650,807.72mph), or a little under 1,800 miles per second, assuming he takes no time actually to deliver the presents or stop for any comfort breaks.
http://www.telegraph.co.uk/topics/christmas/6859529/Father-Christmass-Christmas-Eve-in-figures.html
This is a massive application of the travelling salesman problem - which if you can work out the optimal solution without running into the heat-death of the universe - you would be a very rich man.
Probably because it's a load of rubbish. Abbreviations of plural words should also be plural, e.g. the abbreviation of telephones would be phones, not phone.
That's what I was thinking. I was just trying to come up with an example but was struggling due to a particularly nasty hangover/allergy combo :( Phones will do just nicely.
