VPNs are an awful lot easier to Man-in-the-middle for example.
To a certain extent, but if you think you're completely safe or anonymous on a VPN; you're not.
A VPN is sufficient though for normal people to protect their privacy, ISP's will not have logs of users internet activity and any website that is compromised will not be able to trace access back to the users real ip address.
Are we talking VPN, proxy, or P2P routing here? I think these terms get thrown around and not properly understood...
Using a secure tunnel to connect to a server in some data center would not give you any anonymity, given that the server could be proven to be owned by you, and thus any web traffic coming from that box would be provably your web traffic.
So what are you guys meaning when you say VPN? Tor? Something else?
depends on the setup I imagine a lot of people are referring to shared VPNs i.e. The server all the outgoing requests come from will be many people utilising it. No way to tell who sent what in that situation afaik(assuming they're not logging).
Seems a bit overkill to set up your own server as unless you chose a country and company who won't play ball with the UK and actually know what they're doing security wise then it's pretty worthless. Guess you could always allow others to use it as well.
In all fairness, I don't see the EU stepping in and trying to stop it right now. If they were, it'd raise my opinion of them significantly.
Ironically having voted to Leave, I'd now like to know if there's any way the British public can push this over to the EU to stop it. I don't think they'd listen to us little people, though.
The new regulation conflicts with other non-European laws and regulations and practices (e.g. surveillance by governments). Companies in such countries should no longer be considered acceptable for processing EU personal data. See EU-US Privacy Shield.
It's not worthless at all, even a dedicated server stops your ISP logging your traffic and gives you anonymity to the operators of the websites your accessing. Yes law enforcement can trace the IP back to you if you're the only one using it as you are the registered owner, but that doesn't make it worthless by any means. It completely depends what you want from a VPN solution. Private servers have the advantages of not being blocked by Netflix.
With a private or dedicated VPN server when the authorities ask, "has this person been on x website" the ISP's answer is going to be "don't know".
Who can view my internet history ?
A list of who will have the power to access your internet connection records is set out in Schedule 4 of the Act. It’s longer than you might imagine:
Fire and rescue authorities under the Fire and Rescue Services Act 2004
The world when your isp gets hacked.
Oh yeah! Show me your internets history!![]()
Your ISP will say "don't know". The ISP being used by the server will see the traffice to those websites originating from that server.
Law enforcement pertinent to that ISP's country says, "Who owns this server?" If it's just one person (you), then you're royally boned. Only now you're wanted by law enforcement in the country hosing the server instead of your own.
Don't see how that helps.
