Black Friday wish list ..
Looking for a superwide monitor...budget is £250 so if the LG comes in quite a bit under it would be nice, otherwise one of the more pricey ones coming in on budget!
Well my wish came true, managed to bag the 29UC88 for £238 delivered...listed at £349.99 on overclockers!
Just bought the JBL E40BT for £45 from Sainsbury's. Sound quality is massively better than the Philips headphones I bought from Argos - the JBLs are actually good. But the fit on my massive noggin isn't great or particularly comfortable.
Bugger. The search continues. I'm tempted to forget the Bluetooth bit, go over budget and buy the 598s. At least the cable is detachable so I shouldn't run in to the same problem as my 555s (cable is knackered).
Bought a fridge freezer for my new house today, don't move till middle of December so was glad I could select a delivery date the day after I move.
Why can't I search through the lightning deals :mad:
Filtering doesn't cut it because you still have to look through 2910239102 pages
