- 8 Jun 2007
Are you going to be putting CyanogenMod on it?
No idea i'm hoping the global rom has been released by the time i get it.
I have a Redmi Note 4 with the Global ROM, like the phone, but not so sure about MIUI.
Can I ask, what launcher people recommend for this phone, should I persevere with the stock MIUI launcher or not?
I was considering changing the Launcher to the basic Google one similar to what is on the Moto G.
Another question, I have installed 2 SIM cards, one UK and one Spanish SIM, but unfortunately every time I make a call I keep getting asked what SIM to use, does anyone know of a good SIM manager that remembers / assigns a SIM card for each contact, similar to the Moto G set up.
Wahey, my Redmi 3S arrived today whilst I was at work.
Got it home and fired it up, updated to MIUI 8 OTA.
Noticed that you can set the language to English (UK) but when setting the locale you can't select UK. Does this matter?
MIUI Version is MIUI Global 8.1 | Stable 8.1.1.0(MALMIDI)
Build Number is MMB29M.
Also do i need to sign up for a Mi Account?
Exact same setup as me, that version of Stable only came through last week so you are bang up to date. I've had very little trouble with mine, just the odd occasional random reboot.
You only need a mi account if you want to download themes from their store or use their cloud services, you get 5GB for free and can backup your call log, text messages, images, videos, contacts and I think calendar; also you can use their find my phone service with a mi account and remote find/wipe. I've used it in the past but have signed out and not using it at the moment.
The battery life is fantastic, but MIUI can be very aggressive in its power management, you might want to make some apps autostart, I have had some issues getting some apps to update and the chronus widget hasn't been updating, moved these apps to autostart and they have all started to behave.
Nillkin frosted case on mine (black case on gold mobile), looks OK and gives me access to all the ports and buttons, protects it well enough too as mine hasn't got a scratch on it...
I had mine on Singapore. I switched to CyanogenMod though.
Bought a Mi5 from geekbuying
dispatched on 19-11
was in Singapore on 22-11
last event is dispatched to overseas (UK , Royal Mail) 24-11
Should be within the UK in about 1-2 days right?
As far as I know if you have a genuine rom then you can just use the update function in the settings to update to miui8. If you cannot update, server errors etc. Then you've probably got a non genuine rom. Then you will need unlock the bootloader and flash a genuine global rom. I had to do this with my mi5 when I got it.
