Frustrating issue with 4 networked PCs
11 Apr 2006
Earth
Hi
I have a really strange problem with one of my support environments.
I have a DSL router coming in from outside world and a 5 port gb switch which then connects to the 4 PCs in the room. The PCs are all the same image but they are called Server, Client1, Client2, Client3. They are all imaged the same but commissioned with different computer names.
My issue is network transfer rates which is affecting the software installed on these PCs. The server contains the main software and database and then clients have the software installed but obtain the shared data from the database. It seems to be causing severe delays calling the information from the server database due to network lag.
Even when I copy a 70mb file from the server to each of the clients it can take 10 minutes. When I transfer it between client to client it is almost instant. So I really can't figure out why the server to client connection is so slow.
I have googled the pants out of this, disabled TCP Auto-Tuning, disabled Large Send Offload (LSO), turned off IPv6 networking as still using IPv4 and cleared DNS.
Still cannot transfer files across quickly and this is having a seriously detrimental effect on workload.
Does anyone know anything that could be causing this?
ok think I worked it out so the results below are the server running iperf3 -s and then I ran iperf3 -c IP of clients and the results are below. 60Mb/sec roughly
C:\iperf>iperf3 -s
Server listening on 5201
Accepted connection from .35, port 49472
[ 5] local .34 port 5201 connected to .35 port 49473
[ ID] Interval Transfer Bandwidth
[ 5] 0.00-1.00 sec 6.68 MBytes 56.0 Mbits/sec
[ 5] 1.00-2.00 sec 7.87 MBytes 66.0 Mbits/sec
[ 5] 2.00-3.00 sec 7.82 MBytes 65.6 Mbits/sec
[ 5] 3.00-4.00 sec 8.05 MBytes 67.5 Mbits/sec
[ 5] 4.00-5.00 sec 7.87 MBytes 66.0 Mbits/sec
[ 5] 5.00-6.00 sec 7.85 MBytes 65.8 Mbits/sec
[ 5] 6.00-7.00 sec 7.93 MBytes 66.5 Mbits/sec
[ 5] 7.00-8.00 sec 7.84 MBytes 65.8 Mbits/sec
[ 5] 8.00-9.00 sec 8.07 MBytes 67.7 Mbits/sec
[ 5] 9.00-10.00 sec 7.88 MBytes 66.1 Mbits/sec
[ 5] 10.00-10.13 sec 991 KBytes 64.9 Mbits/sec
[ 5] 0.00-10.13 sec 0.00 Bytes 0.00 bits/sec sender
[ 5] 0.00-10.13 sec 78.8 MBytes 65.3 Mbits/sec receiver
Accepted connection from .36, port 49325
[ 5] local .34 port 5201 connected to .36 port 49326
[ 5] 0.00-1.00 sec 6.40 MBytes 53.7 Mbits/sec
[ 5] 1.00-2.00 sec 7.88 MBytes 66.1 Mbits/sec
[ 5] 2.00-3.00 sec 7.60 MBytes 63.8 Mbits/sec
[ 5] 3.00-4.00 sec 5.43 MBytes 45.5 Mbits/sec
[ 5] 4.00-5.00 sec 7.48 MBytes 62.8 Mbits/sec
[ 5] 5.00-6.00 sec 7.84 MBytes 65.7 Mbits/sec
[ 5] 6.00-7.00 sec 7.65 MBytes 64.1 Mbits/sec
[ 5] 7.00-8.00 sec 7.90 MBytes 66.3 Mbits/sec
[ 5] 8.00-9.00 sec 7.95 MBytes 66.7 Mbits/sec
[ 5] 9.00-10.00 sec 5.51 MBytes 46.3 Mbits/sec
[ 5] 10.00-10.18 sec 1.54 MBytes 71.9 Mbits/sec
[ 5] 0.00-10.18 sec 0.00 Bytes 0.00 bits/sec sender
[ 5] 0.00-10.18 sec 73.2 MBytes 60.3 Mbits/sec receiver
Accepted connection from .42, port 49538
[ 5] local .34 port 5201 connected to .42 port 49539
[ 5] 0.00-1.00 sec 6.32 MBytes 53.0 Mbits/sec
[ 5] 1.00-2.00 sec 7.68 MBytes 64.4 Mbits/sec
[ 5] 2.00-3.00 sec 7.98 MBytes 67.0 Mbits/sec
[ 5] 3.00-4.00 sec 7.94 MBytes 66.6 Mbits/sec
[ 5] 4.00-5.00 sec 7.57 MBytes 63.5 Mbits/sec
[ 5] 5.00-6.00 sec 8.05 MBytes 67.5 Mbits/sec
[ 5] 6.00-7.00 sec 7.92 MBytes 66.4 Mbits/sec
[ 5] 7.00-8.00 sec 7.70 MBytes 64.6 Mbits/sec
[ 5] 8.00-9.00 sec 7.70 MBytes 64.6 Mbits/sec
[ 5] 9.00-10.00 sec 8.02 MBytes 67.3 Mbits/sec
[ 5] 10.00-10.19 sec 1.44 MBytes 63.4 Mbits/sec
[ 5] 0.00-10.19 sec 0.00 Bytes 0.00 bits/sec sender
[ 5] 0.00-10.19 sec 78.3 MBytes 64.5 Mbits/sec receiver
More interestingly is when I use the client as the -s the speed is massively reduced
C:\iperf>iperf3 -c .37
Connecting to host .37, port 5201
[ 4] local .34 port 49320 connected to .37 port 5201
[ 4] 0.00-1.00 sec 315 KBytes 2.58 Mbits/sec
[ 4] 1.00-2.00 sec 189 KBytes 1.55 Mbits/sec
[ 4] 2.00-3.00 sec 378 KBytes 3.10 Mbits/sec
[ 4] 3.00-4.00 sec 189 KBytes 1.55 Mbits/sec
[ 4] 4.00-5.00 sec 252 KBytes 2.06 Mbits/sec
[ 4] 5.00-6.00 sec 252 KBytes 2.06 Mbits/sec
[ 4] 6.00-7.00 sec 315 KBytes 2.58 Mbits/sec
[ 4] 7.00-8.00 sec 378 KBytes 3.10 Mbits/sec
[ 4] 8.00-9.00 sec 315 KBytes 2.58 Mbits/sec
[ 4] 9.00-10.00 sec 315 KBytes 2.58 Mbits/sec
[ 4] 0.00-10.00 sec 2.83 MBytes 2.37 Mbits/sec sender
[ 4] 0.00-10.00 sec 2.73 MBytes 2.29 Mbits/sec receiver
iperf Done.
4 x dell 9020 computer running Windows 7 32 bit with Broadcom NetExtreme 1gb NIC installed
1 x Level1 5 port switch model GEU-0520
1 x Cisco Router (sorry don't know model number)
Possibly Cat 5e or CAT 6 cabling but don't know for sure.
The thing is this setup is used across several different locations and yet this location is proving to be a nightmare.
You've probably thought of this, but Have you tried a different network cable for the server? from what i understand the client to client communication is fine, but client to server isn't, which suggests the server connection is the limiting factor. I would swap the cable first and then the switch if that didn't help.
Does it go switch, patch lead, patch panel, wall port, patch lead ?
Try other wall ports / cables. Try a basic cable tester between the first patch lead and the last one. -Don't connect it to anything that has power (ie switch or server)
DSL wall socket >patched> DSL Router >patched> 1gb Switch >patched> wall sockets x 4 >patched> PC x 4
I think the bottle neck is on the server patch/cabling as this used to be where a client was connected, we wouldn't have seen the speed errors there so much as a client. Going to swap the machines around to at least see if that proves speed issue.
