- 24 Aug 2005
- Uranus
Make sure your not using night mode or have drc on as these can limit volume. Did you run auto setup? What did it set the levels too?
Those aren't holes they're speaker drivers. Some subwoofers have more than one port. Some are sealed box.
Generally though with -dB scale, you have to have it quite loud on that scale, nothing happens much until you reach -20dB.
Why are you streaming flac via Bluetooth?
If both devices support aptX, it shouldn't affect the sound quality.
does the amp not have auto phase ? regardless of that getting the cables the wrong way round wont affect the sound level
Not sound level but it will affect perceived volume since the sound won't appear to come from the speaker.
If you're using absolute volume then its pretty meaningless.
you should be using relative ( -80.5db to +18db) then when calibrated youd know that -30db on your amp is the same as -30db on somebody elses calibrate amp, and 0db is reference level.
it absolutely would affect the sound level. With speakers out of phase you've got speakers working against eachother to cancel eachother out - it's going to have an affect on everything.
[*]Enclosure Type: 2-Way Reflex
[*]Bass Unit: 125m
[*]Treble Unit: 25mm
[*]Frequency Response: 64Hz - 22kHz
[*]Nominal Impedance: 6ohm
[*]Minimum Impedance: 4.0ohm
[*]Sensitivity: 88dB
[*]Crossover Frequency: 2.9kHz
[*]Dimensions H/D/W mm: 265 x 278 x 170
[*]Sold in: Pairs
[*]Weight: 6kg
"As you can see if I set them to small it automatically enables the subwoofer setting when I don't have one. If I disable the subwoofer it automatically changes the speaker type to large. What should I use?"
Small. Then buy a subwoofer.
If you set to large, that means full range is sent to your speakers, which are incapable of playing LFE + bass safetly.
As for levels, do the calibration as that sets them for you.#
No, you want to set the crossover higher than the speaker. For yours I'd set it to 80hz.
Distance is set by calibration as well.
Biwiring won't make a difference.
It doesn't matter which volume scale you use. Choose whichever one you prefer, negative scale or the other
