So updated my old Onkyo with a Denon AVR X3300 (2016 model) (all singing and dancing) which I mainly wanted as it was network connected and I could control via the app plus give more oomph to my sound system.
After being on the phone for an hour with Denon we decided the Audassey mic was not working so now have to wait a while as they are sending a new one out.
The sound pass through comes from my PC which has always worked flawlessly, getting TrueHD etc to display on the certain movie files that have it.
With the new Amp, I can't seem to get that working
always just DTS.
If I select passthrough on AMP settings the signal constantly flickers in and out (as if it's searching).
If I play a SD quality audio movie (usually one of my sons) the subwoofer is not even used?
When the old Onkyo would still make it sound wonderful.
There is also red specks all over black areas on the movies, a quick google suggests this might be (hopefully) the HDMI cable.....but it wasn't doing that before.
Having tested it on a few movies, it does sound amazing, but so many things I'm scratching my head over and just not running smoothly I'm not sure what to do. I know the output from the PC is fine as it was always running great. I bought a $1k amp to get all the fixings, but can't seem to get the basics out of it just yet.
Probably going to call Denon back but that takes forever and an age.
always just DTS.If I select passthrough on AMP settings the signal constantly flickers in and out (as if it's searching).
When the old Onkyo would still make it sound wonderful. There is also red specks all over black areas on the movies, a quick google suggests this might be (hopefully) the HDMI cable.....but it wasn't doing that before.
