Chocolate of all forms is getting worse, supposedly its becoming an increasingly scarce commodity.
Many things are getting bad, i dislike the way meat comes loaded up with water these days to the level that microwaving a slice of ham for ten seconds is a way to halve the volume and double the flavour, and you dont so much fry mince as spend 30 minutes boiling off the water before getting to the actual frying bit.
Its not just food, everythings bloody consumable these days to the stage you couldnt fix it even if you wanted to. Mobile phones starting to have too much plastic on a top of the line device when not 5 years ago it'd have been aluminium and theyre all glued together anyway, also since when did "gorillaglass" scratch so easily? I had a samsung years ago with a gorillaglass screen and you couldnt have scratched it with a hammer and a chisel.
Reduce, reuse and recycle is soon going to be impossible, what happened to people actually making spares?
