Juddery wiper blades
14 Dec 2004
South
Bought a second hand car and as always the blades juddered.
So I bought some bosch aero blades, clayed the screen, used an alcohol wipe I had from some previous blades and thought that will do.
Nope, the new blades judder.
I've since washed the car and the shampoo has some wax in it, I thought that would make it slippery, nope, still judder.
Any tips to stop this?
Seems quite weird, as above I'd try some polish but I'd have thought that the clay would have removed anything that could be causing it.
Forgot to say I did use 't cut' glass polish after claying it.
I can do it all again, see what happens.
Not sure how I'll keep the shampoo off the screen :confused:
Polish the glass, perhaps use a glass cleaner or alcohol wipes to take off the polish, try the blades.
Be side to remove all the wax from the rubber on the blades too.
Just seems to be an increasingly common thing with either newer cars or newer wiper blades.
My old mazda 323f circa 1999 was rarely washed, never clayed nor polished, yet with the cheapest of halfrauds wipers would be a quiet streak free wipe.
The skoda was hopeless, nothing could stop it.
The bm is mostly judder free but not streak free, with bosch aeroblades.
The only thing i've ever found is just using plain water as screenwash can help, some soap mixes make the screen too clean and it judders.
Could be the wiper arms have been bashed slightly out of shape, i've seen that on some cars. Not quite sure what the easiest solution to that is though!
I had judder on the old BMW. It was from whatever crap the garage had sprayed on the windows before they sold it to me. As it was wearing off it judder education like mad and gradually faded. No amount of washing seemed to help though.
Go get some bar keepers freind from your local supermarket and polish it with that to get some bar keepers freind from your local supermarket and polish it with that should sort the issue out
Put some sealant on the windscreen. Using bouncers drop and roll myself get about 3 months per application on windscreen or 1 year for side windows. Dont need the wipers at all above about 60mph and when i do there much smoother.
I remember the Fiat Punto used to judder because it had cheap plastic linkages. At one point you were actually able to by a metal replacement and fit.
