If im <30p away from a round number i'll feather the trigger. Am I a bad person?![]()
I'm forever trying to explain to drivers at work not to overfill the truck tanks, especially Scania trucks as they recirculate unused (hot) fuel back into the tanks which expands and is then dumped into the road,especially by our depot near Junction 15 of the M6, as you exit the depot you have to take a sharp turn which exacerbates the issue and makes the junction (by Hanchurch Crossroads for any locals) treacherous, especially for bikers.
Having seen a few bikers come off outside our depot I can assure it's quite a drama for them!
Alas, many of our drivers are convinced that brimming the tanks is the only way to fill them even though you can easily do Stoke-London and back on half a tank!
That's pretty much what most diesel vehicles do, especially common rail ones, where sometimes more fuel can be returned to the tank than is actually used by the engine.I'm forever trying to explain to drivers at work not to overfill the truck tanks, especially Scania trucks as they recirculate unused (hot) fuel back into the tanks which expands ~
Guessing you're not a motorcyclist
http://www.righttoride.co.uk/top-issues/roads-infrastructure/diesel-spills/ here educate yourself
More drama, and assumptions![]()
It's, the lorries you need to roll your eyes at here.
I'm not sure I fully understand why you feel you must brim the tank anyway, I mean I fill my tank and don't have to return for just shy of 500 miles, the last few dribbles really aren't going to matter and yet run the risk of this...
All sorts of odd aerodynamics go on around a wheel at motorway speeds, so if any excess diesel found its way out anywhere in the vicinity - its fairly probably it would get deposited in the nearest low pressure area
Most include some kind of cooler in the return line to reduce the expansion effect though. Maybe in this case the tank was so full that even that wasn't enough.
Assumed it was specific to Scanias as after a long drive I've noticed the fuel tanks (our Scanias have twin tanks) are warm to the touch where those on Volvo's and Mercedes are stone cold, I'd have thought they were all common rail designs though.
