Onkyo 9010 stereo amp ..WiFi
Hi ..
Most amps don't come with networking as std .. You have to look for the ones that say they do ..
By either having a RJ 45 socket on the back ..
Or build in wifi .. Or both ..
If your lucky some support a USB dongle for wifi .. Which can be bought as a extra normally
You need to have a look thru your manual ..
Probally looking at a Pi and then analogue audio into the line in.
If you tell us what you are trying to achieve with making it wifi enabled we might be able to offer a better solution.
What is Chromecast Audio?
Chromecast Audio is a small media streaming device that plugs into the AUX input of your speaker, making your speaker Wi-Fi enabled.
Once set up, simply use your iPhone®, iPad®, Android phone or tablet, Mac or Windows laptop, or Chromebook to cast your favourite tunes to the best speakers in the house.
Supports rca, 3.5mm and optical according to the blurb
Thanks , just trying to stream music from my ipad to the audio amp
cheers for that ill take a look :)
http://www.maplin.co.uk/p/google-chromecast-audio-a86ut?cmpid=ppc&gclid=CJncwcKM59ACFYccGwody9YNog
looks like it should do the job nicely thank you :)
Thanks for recommending the chrome cast . Works really well , just need my iPad to find the Nas now
